查看: 20269|回复: 28
[原创] 什么是native nmos model
发表于 2012-7-5 10:58:08 | 显示全部楼层 |阅读模式
这种管子有什么用啊啊啊啊啊啊??????????????
// *                              1.8v native nmos model                              *
model nnt18 bsim3v3 type=n
// * general parameters
+lmin = 4.5e-7 lmax = 1.0e-5 wmin = 1.9e-7
+wmax = 1.0e-4 tnom = 25.0 version = 3.24
+tox = 3.87e-09+dtox_nnt18 toxm = 3.87e-09 xj = 1.6000000e-07
+nch = 4.4440000e+16 lln = 1.0000000 lwn = 1.0000000
+wln = 1.0000000 wwn = 1.0000000 lint = 3.2000000e-08
+ll = 0.00 lw = 0.00 lwl = 0.00
+wint = 0.00 wl = 0.00 ww = 0.00
+wwl = 0.00 mobmod = 1 binunit = 2
+xl = 2.5e-8+dxl_nnt18 xw = 0.00+dxw_nnt18 dwg = 0.00
+dwb = 0.00
// * diode parameters
+dskip = no ldif = 7.00e-08 hdif = 2.0e-07
+rsh = 7.08 rd = 0 rs = 0
+rsc = 1 rdc = 1
// * threshold voltage parameters
+vth0 = -0.015+dvth_nnt18 lvth0 = 2.8000000e-08 k1 = 9.6053920e-02
+k2 = -2.5212668e-02 k3 = -0.5717283 dvt0 = 1.0000000e-02
+dvt1 = 0.00 dvt2 = -1.0000000e-02 dvt0w = -9.0000010e-02
+dvt1w = 1.3570372e+05 dvt2w = 0.00 nlx = 4.3929600e-07
+w0 = 0.00 k3b = -0.8582231 pvth0=0+dpvth0_nnt18
// * mobility parameters
+vsat = 1.3500000e+05 lvsat = -1.8200000e-02 wvsat = 1.0000000e-04
+pvsat = 3.6000000e-09 ua = 9.6000e-10 lua = -5.0000000e-17
+pua = -3.0000002e-23 ub = 2.1696805e-18 uc = -2.2999993e-11
+wuc = -3.5000000e-17 puc = 2.0000000e-23 rdsw = 1.2000000e+02
+prwb = 0.00 prwg = 0.00 wr = 1.0000000
+u0 = 6.1000000e-02 wu0 = 2.2000000e-09 pu0 = -1.0000000e-16
+a0 = 1.5500000 keta = -2.9847301e-03 a1 = 0.00
+a2 = 0.9800000 ags = 1.5000000 b0 = 0.00
+b1 = 0.00
// * subthreshold current parameters
+voff = -0.1100000 nfactor = 1.0000000 cit = 1.9915700e-04
+cdsc = 0.00 cdscb = 0.00 cdscd = 0.00
+eta0 = 8.0000000e-02 leta0 = 4.0000000e-08 peta0 = 5.0000000e-14
+etab = -1.0000000e-02 petab = 8.0000000e-15 dsub = 0.5600000
// * rout parameters
+pclm = 1.6000000 pdiblc1 = 1.0000000e-02 pdiblc2 = 0.1200000
+pdiblcb = 5.7750700e-02 drout = 0.5600000 pscbe1 = 6.4335600e+08
+pscbe2 = 1.0000000e-20 pvag = 0.00 delta = 1.0000000e-02
+alpha0 = 9.3800000e-09 alpha1 = 1.0385719e-02 beta0 = 5.8915170
// * temperature effects parameters
+kt1 = -0.2961084 kt2 = 1.0000000e-03 at = 2.0456400e+04
+ute = -1.6500000 wute = -1.1000000e-09 ua1 = 3.8350100e-09
+wua1 = -2.0736400e-16 pua1 = 6.0000000e-23 ub1 = -7.4901900e-18
+wub1 = -1.7708197e-26 uc1 = -6.6000000e-11 kt1l = -7.4000000e-15
+prt = 0.00
// * noise parameters
+noimod = 2 noia = 4.4361E+20 noib = 1.0074E+04
+noic = 2.9928E-13 em = 1.039E+06 ef = 9.075E-01
// * capacitance parameters
+cj = 1.45e-04+dcj_nnt18 mj = 0.334 pb = 0.538
+cjsw = 1.63e-10+dcjsw_nnt18 mjsw = 0.0689 pbsw = 0.563
+cjswg = 6.60e-11+dcjswg_nnt18 mjswg = 0.0689 pbswg = 0.563
+tcj = 0.00246 tcjsw = 0.00122 tcjswg = 0.00122
+tpb = 0.00277 tpbsw = 0.00204 tpbswg = 0.00204
+js = 5.2e-06 jsw = 1.0e-13 n = 1.0651
+xti = 3 nqsmod = 0 elm = 5
+cgdo = 2.66e-10+dcgdo_nnt18 cgso = 2.66e-10+dcgso_nnt18 tlevc = 1
+capmod = 3 xpart = 1 cf = 0.00
+acde = 0.64 moin = 24 noff = 2.50
发表于 2012-7-5 11:51:39 | 显示全部楼层
回复 1# tiancai3385
   very low Vt,接近0或为负,可用于reference中的curvature compensation,或是souce follower,或低压应用
发表于 2012-8-13 12:12:34 | 显示全部楼层
借光问个问题,我用到了TSMC 0.18um工艺库的native mos,在HSPCIE仿真时它提示我输入模型名有误?TMSC工艺库文件里native MOS名为NANCH,难道NMOS模型名只能是NCH?这样的话,HSPICE如何知道我选的哪个管子呢?
发表于 2013-8-16 18:05:53 | 显示全部楼层
在标准逻辑工艺中,有时候我们会见到Native MOS管,什么叫做Native MOS管呢?
正巧目前的一颗IC正好用到这个东西,于是询问,才知道Native MOS实际就是阈值电压接近为零的管子,实际上就是耗尽管。但是为什么叫做Native MOS呢? 原来是最早的MOS制程中由于氧化层带有电荷,很难做很干净的氧化层,所以做出来的NMOS,氧化层本身带有正电荷,导致未加正电压就导通了。当今这种阈值电压接近0的NMOS可不是通过氧化层中带电来完成的,而是通过调整沟道参杂来完成的。但是结果一样,于是还是叫Native MOS管。
这种Native MOS管一般只会用来做电容,用它做电容的好处在于,以NMOS为例,gate电压只要大于阈值电压,那么电容都等于Gate电容。而标准NMOS,当gate电压小于阈值电压的时候,NMOS电容等于gate电容和沟道耗尽层电容的串联,是电容值变小很多。所以在130nm制程之后,我们会经常看到Native NMOS/PMOS作为电容使用。(转自http://blog.sina.com.cn/s/blog_6f55e2aa0100n5mf.html)
回复 支持 2 反对 0
发表于 2013-8-16 18:09:22 | 显示全部楼层
native管其实就是做在epi(就是P-)上的nmos。具体来说,我们普通的所谓nwell的cmos工艺是双阱工艺,也就是在epi上长两种阱,非N即P,但是native管是直接做在epi上的,这个地方不做NWELL也不做PWELL。
该管子的特点就是低开启或者负开启,一般用在低压模拟电路中。
也有些缺点:可能不能完全关断或者漏电较大,某些情况下不适合做开关用;和一普通管子相比规则可能比较大,或者工艺最小尺寸比较大;epi的一致性或均匀性可能比阱差,所以管子特性的匹配性差一些。(转自http://www.newsmth.net/nForum/#!article/METech/168764)
发表于 2013-8-29 17:02:26 | 显示全部楼层
刚好要用Native MOS做Pump电容
发表于 2013-8-29 20:20:16 | 显示全部楼层
回复 1# tiancai3385
   在TSMC的手册中有看到过主要用作电容 你可以找手册仔细看下
回复 支持 0 反对 1
发表于 2014-9-19 15:28:57 | 显示全部楼层
学习了
发表于 2015-6-22 11:08:52 | 显示全部楼层
学习了。。。
发表于 2015-6-22 11:33:02 | 显示全部楼层
   学到好多····
GMT+8, 2025-9-11 22:49 , Processed in 0.019583 second(s), 5 queries , Gzip On, Redis On.
