楼主: sun-moon
[求助] [已解决] 求助,ICC ,power straps short 了!!!
发表于 2015-10-21 17:16:35 | 显示全部楼层
看一下
发表于 2015-10-22 08:45:39 | 显示全部楼层
感谢受教了,在哪里设置stripe的层次?encounter和icc
发表于 2016-3-22 15:33:21 | 显示全部楼层
好樣的,Good!學習了!
发表于 2020-4-5 21:04:40 | 显示全部楼层
受教了,同时本人查阅了一下相关的ICC set_pnet_options 的可选项如下
ARGUMENTS
       -partial
              Allows  standard cells to be placed under pnets, but the pins in
              the standard cells are checked to prevent shorts with the pnets.
              The  -partial, -complete, and -none options control how the tool
              places the cell under the pnets.  These three options are  mutu-
              ally exclusive; you can specify only one.  If you do not specify
              any of these options, -none is used as the default.
       -complete
              Prevents cells from ever overlapping  with  pnets.   A  pnet  is
              treated  as  a  placement keepout.  The -partial, -complete, and
              -none options control how the tool places  the  cell  under  the
              pnets.   These  three  options  are  mutually exclusive; you can
              specify only one.  If you do not specify any of  these  options,
       -none  Allows  cells  to  be freely placed under pnets without checking
              for electrical shorts.  The pnets are  invisible  during  place-
              ment.   The  -partial,  -complete, and -none options control how
              the tool places the cell under the pnets.  These  three  options
              are mutually exclusive; you can specify only one.  If you do not
              specify any of these options, -none is used as the default.
其中default -none 对pnet下的stdcel pin 没有进行检查和限制 是free的,避免short应该是要注意要添加适合选项。
GMT+8, 2025-12-19 15:36 , Processed in 0.016200 second(s), 3 queries , Gzip On, Redis On.
