查看: 7289|回复: 18
[求助] 为什么我的corner摆不到四个角?
发表于 2012-6-15 11:30:57 | 显示全部楼层 |阅读模式
我用encounter生成的io文件修改pad和corner的摆放位置,可是不知道为什么corner老是摆到了东边,放不到四个角,附上pad摆放的图,网标和顶层文件,恳请大侠指教 ,怎么能摆放正确!
图中的C1-C4就是我加的corner。(我想是不是因为我在网标中加的corner不正确所致,不敢肯定,第一次加corner。也可能是因为其他原因吧) io文件.doc (18 KB , 下载次数: 12 ) Screenshot.png
 楼主| 发表于 2012-6-15 11:34:48 | 显示全部楼层
io文件不知怎么的传不上去,我写出来吧。
(globals
    version = 3
    io_order = default
(        Pad: CLK_PAD_U N
         Pad: NRST_N_PAD_U N
         Pad: CPU_CE_PAD_U N
         Pad: CPU_WE_N_PAD_U N
         Pad: CPU_ADDR_0_PAD_U N
         Pad: CPU_ADDR_1_PAD_U N
         Pad: CPU_ADDR_2_PAD_U N
         Pad: CPU_ADDR_3_PAD_U N
         Pad: CPU_DIN_0_PAD_U N
         Pad: CPU_DIN_1_PAD_U N
         Pad: CPU_DIN_2_PAD_U N
         Pad: CPU_DIN_3_PAD_U N
         Pad: CPU_DIN_4_PAD_U N
         Pad: CPU_DIN_5_PAD_U N
         Pad: CPU_DIN_6_PAD_U N
         Pad: CPU_DIN_7_PAD_U N
         Pad: CPU_DIN_8_PAD_U N
         Pad: CPU_DIN_9_PAD_U N
         Pad: CPU_DIN_10_PAD_U N
         Pad: CPU_DIN_11_PAD_U N
         Pad: C1 NE
Orient:R0
          Pad: C2 SW
          Pad: CPU_DIN_12_PAD_U W
          Pad: CPU_DIN_13_PAD_U W
          Pad: CPU_DIN_14_PAD_U W
          Pad: CPU_DIN_15_PAD_U W
          Pad: CPU_DIN_16_PAD_U W
          Pad: CPU_DIN_17_PAD_U W
          Pad: CPU_DIN_18_PAD_U W
          Pad: CPU_DIN_19_PAD_U W
          Pad: CPU_DIN_20_PAD_U W
          Pad: CPU_DIN_21_PAD_U W
          Pad: CPU_DIN_22_PAD_U W
          Pad: CPU_DIN_23_PAD_U W
          Pad: CPU_DIN_24_PAD_U W
          Pad: CPU_DIN_25_PAD_U W
          Pad: CPU_DIN_26_PAD_U W
          Pad: CPU_DIN_27_PAD_U W
          Pad: CPU_DIN_28_PAD_U W
          Pad: CPU_DIN_29_PAD_U W
          Pad: CPU_DIN_30_PAD_U W
          Pad: CPU_DIN_31_PAD_U W
          Pad: C3 NW
          Pad: DES_BUSY_PAD_U S
          Pad: DES_DONE_PAD_U S
          Pad: CPU_DOUT_0_PAD_U S
          Pad: CPU_DOUT_1_PAD_U S
          Pad: CPU_DOUT_2_PAD_U S
          Pad: CPU_DOUT_3_PAD_U S
          Pad: CPU_DOUT_4_PAD_U S
          Pad: CPU_DOUT_5_PAD_U S
          Pad: CPU_DOUT_6_PAD_U S
          Pad: CPU_DOUT_7_PAD_U S
          Pad: CPU_DOUT_8_PAD_U S
          Pad: CPU_DOUT_9_PAD_U S
          Pad: CPU_DOUT_10_PAD_U S
          Pad: CPU_DOUT_11_PAD_U S
          Pad: CPU_DOUT_12_PAD_U S
          Pad: CPU_DOUT_13_PAD_U S
          Pad: CPU_DOUT_14_PAD_U S
          Pad: CPU_DOUT_15_PAD_U S
          Pad: CPU_DOUT_16_PAD_U S
          Pad: CPU_DOUT_17_PAD_U S
          Pad: C4 SE
          Pad: CPU_DOUT_18_PAD_U E
          Pad: CPU_DOUT_19_PAD_U E
          Pad: CPU_DOUT_20_PAD_U E
          Pad: CPU_DOUT_21_PAD_U E
          Pad: CPU_DOUT_22_PAD_U E
          Pad: CPU_DOUT_23_PAD_U E
          Pad: CPU_DOUT_24_PAD_U E
          Pad: CPU_DOUT_25_PAD_U E
          Pad: CPU_DOUT_26_PAD_U E
          Pad: CPU_DOUT_27_PAD_U E
          Pad: CPU_DOUT_28_PAD_U E
          Pad: CPU_DOUT_29_PAD_U E
          Pad: CPU_DOUT_30_PAD_U E
          Pad: CPU_DOUT_31_PAD_U E
          Pad: VDD_PAD_U E
          Pad: GND_PAD_U E
 楼主| 发表于 2012-6-15 16:05:04 | 显示全部楼层
自己默默顶一个
发表于 2012-6-15 16:51:00 | 显示全部楼层
用location 的file format
要写left bottom right and top 否则只是一个顺序
并不是一个位置
发表于 2012-6-15 17:35:40 | 显示全部楼层
手放不可以吗? 必须上脚本?
 楼主| 发表于 2012-6-16 09:29:16 | 显示全部楼层
回复 4# conniezhou
  encounter生成的io文件刚开始有left bottom right and top,但四个角不好定义啊,被我改成N,S,E,W了
 楼主| 发表于 2012-6-16 09:30:31 | 显示全部楼层
回复 5# chris_li
    手放老没成功
 楼主| 发表于 2012-6-16 09:51:24 | 显示全部楼层
还是不行啊,它还是自动默认corner在右边,改io改不过来,是不是因为我的网标改的不正确?
发表于 2012-6-16 11:02:38 | 显示全部楼层
回复 8# 日月木易
    试试这个呢,以前在资料上看到的,我没有项目试过,不知道可不可行
   Pad: padInstanceName  corner [cellName]
  corner分配一个pad到图形的指定corner,指定为ne,nw,sw或se
 楼主| 发表于 2012-6-16 12:06:56 | 显示全部楼层
回复 9# ppseuradio1
    我试试,先谢过啦
GMT+8, 2025-12-20 20:14 , Processed in 0.045296 second(s), 6 queries , Gzip On, Redis On.
