查看: 7108|回复: 13
[求助] 今天装了IC5141,但是加入13工艺库后不能仿真,求大侠帮助~~~
发表于 2012-6-14 23:30:39 | 显示全部楼层 |阅读模式
Command line:
    /home/xlq/cadence/tools.lnx86/spectre/bin/32bit/spectre -env  \
        artist5.1.0 +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre0_15245_1 -format sst2 -raw ../psf  \
        +lqtimeout 900 input.scs
spectre pid = 15406
Loading /home/xlq/cadence/tools.lnx86/cmi/lib/4.0/libinfineon_sh.so ...
Loading /home/xlq/cadence/tools.lnx86/cmi/lib/4.0/libnortel_sh.so ...
Loading /home/xlq/cadence/tools.lnx86/cmi/lib/4.0/libphilips_sh.so ...
Loading /home/xlq/cadence/tools.lnx86/cmi/lib/4.0/libsparam_sh.so ...
Loading /home/xlq/cadence/tools.lnx86/cmi/lib/4.0/libstmodels_sh.so ...
spectre (ver. 5.10.41_USR3.102405 -- 24 Oct 2005).
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
        Security, Inc.
Simulating `input.scs' on ivy at 11:15:06 PM, Thur Jun 14, 2012.
Error found by spectre in `dnw12_ckt', during circuit read-in.
    "/home/xlq/cadence/pdk/smic13mmrf_1233_cds_1P8M_2011_3_31_v1.8/smic13mmrf_1233/../models/spectre/ms013_io33_v2p5_spe.mdl"
        1039: Unknown parameter name `l' used to initialize parameter `lr'.
        1039: Unknown parameter name `w' used to initialize parameter `wr'.
        1039: Unknown parameter name `ladd' used to initialize parameter
        `laddr'.
        1039: Unknown parameter name `wadd' used to initialize parameter
        `waddr'.
        1039: Unknown parameter name `sa' used to initialize parameter `sar'.
        1039: Unknown parameter name `sb' used to initialize parameter `sbr'.
        1167: Unknown parameter name `djs_rwdio33' found in expression.
        1167: Unknown parameter name `djsw_rwdio33' found in expression.
        1167: Unknown parameter name `dn_rwdio33' found in expression.
        1167: Unknown parameter name `dcj_rwdio33' found in expression.
        1167: Unknown parameter name `dcjsw_rwdio33' found in expression.
        1182: Unknown parameter name `djs_dnwdio33' found in expression.
        1182: Unknown parameter name `djsw_dnwdio33' found in expression.
        1182: Unknown parameter name `dn_dnwdio33' found in expression.
        1182: Unknown parameter name `dcj_dnwdio33' found in expression.
        1182: Unknown parameter name `dcjsw_dnwdio33' found in expression.
Error found by spectre in `dnwhvt12_ckt', during circuit read-in.
        1196: Unknown parameter name `l' used to initialize parameter `lr'.
        1196: Unknown parameter name `w' used to initialize parameter `wr'.
        1196: Unknown parameter name `ladd' used to initialize parameter
        `laddr'.
        1196: Unknown parameter name `wadd' used to initialize parameter
        `waddr'.
        1196: Unknown parameter name `sa' used to initialize parameter `sar'.
        1196: Unknown parameter name `sb' used to initialize parameter `sbr'.
        1310: Unknown parameter name `djs_rwdio33' found in expression.
        1310: Unknown parameter name `djsw_rwdio33' found in expression.
        1310: Unknown parameter name `dn_rwdio33' found in expression.
        1310: Unknown parameter name `dcj_rwdio33' found in expression.
        1310: Unknown parameter name `dcjsw_rwdio33' found in expression.
        1325: Unknown parameter name `djs_dnwdio33' found in expression.
        1325: Unknown parameter name `djsw_dnwdio33' found in expression.
        1325: Unknown parameter name `dn_dnwdio33' found in expression.
        1325: Unknown parameter name `dcj_dnwdio33' found in expression.
        1325: Unknown parameter name `dcjsw_dnwdio33' found in expression.
Error found by spectre in `dnwlvt12_ckt', during circuit read-in.
        1337: Unknown parameter name `l' used to initialize parameter `lr'.
        1337: Unknown parameter name `w' used to initialize parameter `wr'.
        1337: Unknown parameter name `ladd' used to initialize parameter
        `laddr'.
        1337: Unknown parameter name `wadd' used to initialize parameter
        `waddr'.
        1337: Unknown parameter name `sa' used to initialize parameter `sar'.
        1337: Unknown parameter name `sb' used to initialize parameter `sbr'.
        1451: Unknown parameter name `djs_rwdio33' found in expression.
        1451: Unknown parameter name `djsw_rwdio33' found in expression.
        1451: Unknown parameter name `dn_rwdio33' found in expression.
        1451: Unknown parameter name `dcj_rwdio33' found in expression.
        1451: Unknown parameter name `dcjsw_rwdio33' found in expression.
        1466: Unknown parameter name `djs_dnwdio33' found in expression.
        1466: Unknown parameter name `djsw_dnwdio33' found in expression.
        1466: Unknown parameter name `dn_dnwdio33' found in expression.
        1466: Unknown parameter name `dcj_dnwdio33' found in expression.
        1466: Unknown parameter name `dcjsw_dnwdio33' found in expression.
Error found by spectre in `dnw33_ckt', during circuit read-in.
        1479: Unknown parameter name `l' used to initialize parameter `lr'.
        1479: Unknown parameter name `w' used to initialize parameter `wr'.
        1479: Unknown parameter name `ladd' used to initialize parameter
        `laddr'.
        1479: Unknown parameter name `wadd' used to initialize parameter
        `waddr'.
        1479: Unknown parameter name `sa' used to initialize parameter `sar'.
        1479: Unknown parameter name `sb' used to initialize parameter `sbr'.
        1600: Unknown parameter name `djs_rwdio33' found in expression.
        1600: Unknown parameter name `djsw_rwdio33' found in expression.
        1600: Unknown parameter name `dn_rwdio33' found in expression.
        1600: Unknown parameter name `dcj_rwdio33' found in expression.
        1600: Unknown parameter name `dcjsw_rwdio33' found in expression.
        1615: Unknown parameter name `djs_dnwdio33' found in expression.
        1615: Unknown parameter name `djsw_dnwdio33' found in expression.
        1615: Unknown parameter name `dn_dnwdio33' found in expression.
        1615: Unknown parameter name `dcj_dnwdio33' found in expression.
        1615: Unknown parameter name `dcjsw_dnwdio33' found in expression.
spectre terminated prematurely due to fatal error.
上面是提示的语句,在公司链接服务器完全没有问题,但是自己装的5141不知道是怎么回事,查了些,有人说是5141的spectre的版本过低,不知道是不是这样的,如果这样,需要怎么解决
 楼主| 发表于 2012-6-14 23:38:15 | 显示全部楼层
当我把仿真的模型的后缀由.scs形式改成.lib形式后,出现以下提示
Command line:
        +mpssession=spectre0_15795_1 -format sst2 -raw ../psf  \
spectre pid = 15963
        Security, Inc.
Simulating `input.scs' on ivy at 11:26:50 PM, Thur Jun 14, 2012.
Error found by spectre during circuit read-in.
        115: Syntax error in specification of `vth0'.
        146: Syntax error in specification of `cf'.
        156: Syntax error in specification of `sa0'.
        250: Syntax error in specification of `vth0'.
        260: Syntax error in specification of `sa0'.
        328: Syntax error in specification of `vth0'.
        358: Syntax error in specification of `cf'.
        401: Syntax error in specification of `vth0'.
        424: Syntax error in specification of `pu0'.
        454: Syntax error in specification of `cf'.
        510: Syntax error in specification of `vth0'.
        543: Syntax error in specification of `cf'.
        597: Syntax error in specification of `vth0'.
        629: Syntax error in specification of `cf'.
        700: Syntax error in specification of `vth0'.
        729: Syntax error in specification of `cf'.
        743: Syntax error in specification of `sa0'.
        796: Syntax error in specification of `vth0'.
        828: Syntax error in specification of `cf'.
        842: Syntax error in specification of `sa0'.
        906: Syntax error in specification of `vth0'.
        937: Syntax error in specification of `cf'.
        1002: Syntax error in specification of `vth0'.
        1031: Syntax error in specification of `cf'.
        `laddr'.
        `waddr'.
        1108: Syntax error in specification of `vth0'.
        1139: Syntax error in specification of `cf'.
        1150: Syntax error in specification of `sa0'.
        `laddr'.
        `waddr'.
        1262: Syntax error in specification of `vth0'.
        1292: Syntax error in specification of `cf'.
        `laddr'.
        `waddr'.
        1379: Syntax error in specification of `vth0'.
        1402: Syntax error in specification of `pu0'.
        1432: Syntax error in specification of `cf'.
        `laddr'.
        `waddr'.
        1571: Syntax error in specification of `vth0'.
        1583: Syntax error in specification of `sa0'.
发表于 2012-8-11 17:45:54 | 显示全部楼层
估计你装的版本太旧了,升级下吧
 楼主| 发表于 2012-12-20 22:47:36 | 显示全部楼层
升级了MMSIM版本可以用了
发表于 2012-12-22 12:30:20 | 显示全部楼层
HAO WEN TI A
发表于 2012-12-23 13:01:45 | 显示全部楼层
好东西啊啊
发表于 2012-12-23 13:12:00 | 显示全部楼层
好东西啊啊
发表于 2012-12-23 13:14:49 | 显示全部楼层
好东西啊啊
发表于 2013-12-11 15:02:44 | 显示全部楼层
楼主能把库给我下吗?
发表于 2013-12-15 16:06:30 | 显示全部楼层
顶一下。。。。
GMT+8, 2025-12-22 19:21 , Processed in 0.025042 second(s), 6 queries , Gzip On, Redis On.
