查看: 4118|回复: 5
[求助] 求助 Special route "Error" in SOC Encounter [已解決]
发表于 2012-6-7 17:57:36 | 显示全部楼层 |阅读模式
嗨~大家好
我在做SOC encounter遇上了些問題, 想向各路英雄求救。
我在加完power ring之後要做Special route(pad pins)的時候,terminal出現錯誤訊息顯示:
Reading LEF technology information...
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 374: cannot add PIN QA[0] to MACRO dp_rf_256x8 at or near "QA[0]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 386: cannot add PIN QA[1] to MACRO dp_rf_256x8 at or near "QA[1]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 398: cannot add PIN QA[2] to MACRO dp_rf_256x8 at or near "QA[2]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 410: cannot add PIN QA[3] to MACRO dp_rf_256x8 at or near "QA[3]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 422: cannot add PIN QA[4] to MACRO dp_rf_256x8 at or near "QA[4]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 434: cannot add PIN QA[5] to MACRO dp_rf_256x8 at or near "QA[5]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 446: cannot add PIN QA[6] to MACRO dp_rf_256x8 at or near "QA[6]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 458: cannot add PIN QA[7] to MACRO dp_rf_256x8 at or near "QA[7]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 473: cannot add PIN VDD to MACRO dp_rf_256x8 at or near "VDD"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 488: cannot add PIN VSS to MACRO dp_rf_256x8 at or near "VSS"
A total of 10 errors.
我也檢查過QA這個PIN在netlist裡面都有連接正確,我也用memory compiler重新產生memory model再帶入
可是還是失敗。
請教高手這問題的原因是什麼?
感謝 ^_^
发表于 2012-6-7 19:36:32 | 显示全部楼层
比较奇怪,具体看看那行写啥, vclef,是arm的吧,啥工艺,
实在不行手拉stripe吧,  addWire,
 楼主| 发表于 2012-6-7 20:07:57 | 显示全部楼层
對的~是arm的, .18製程~~
手拉嗎~~ @@a
真的解不開會試試看的, 感謝 ^^
发表于 2012-6-8 06:38:05 | 显示全部楼层
看看addWire 行否,  E 键,
 楼主| 发表于 2012-6-11 09:17:41 | 显示全部楼层
感謝~ 已解決問題,
原因是因為我import design的時候,lef檔案讀入順序錯誤, vclef要在ant.lef前面被引入。 呵呵
另外想請教一下大家, 我的design中有包含sram和register file可是每次做到special route(standard cell)這一部分, 就很容易出現 Geometry violation和Connectivity (VDD VSS)的antenna violation
錯誤的地方都在sram的邊框附近
如果我把sram換一個地方擺放,就會減少一些錯誤,可是還是無法完全消除錯誤
想請教一下是不是sram這邊有什麼地方還要特別設定的
因為我也有下Edit Halos了。
Connectivity antenna 這個一定要完全消除嗎? 除了手動拉線,Tool能自動修嗎? 感謝大家
发表于 2012-6-12 21:50:53 | 显示全部楼层
encounter的antenna violation有的是dangling stub的意思,可以忽略,
不是真正的gate oxide integrity  antenna violation,  没关系的
GMT+8, 2025-12-21 13:02 , Processed in 0.016564 second(s), 3 queries , Gzip On, Redis On.
