查看: 2616|回复: 3
[求助] 求教:新版encounter 10.10在输入设计时如何输入时序库文件?
发表于 2012-5-23 15:55:28 | 显示全部楼层 |阅读模式
找了半天没找到输入时序库文件(.lib或.tlf)的地方,显示以下warning,不知道是否和没有时序库有关。
**WARN: (ENCSYC-2):    Timing is not defined for cell Y57B.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y565.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y564.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y522.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y521.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y517.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y512.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y511.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y454.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y438NF.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y438.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y437NE.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y435NE.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y435.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y434NC.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y433NG.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y432NH.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y432ND.
**WARN: (ENCSYC-2):    Timing is not defined for cell Y432NA.
发表于 2012-5-23 23:42:21 | 显示全部楼层
仔细看menu
发表于 2014-1-10 08:07:00 | 显示全部楼层
I have the question too.
发表于 2016-3-24 15:56:09 | 显示全部楼层
回复 1# 禅师1988 请问一下,这个问题解决了吗?我已经添加过了.lib文件,但是还是出现这个warning ,在布局布线图形中没有标准单元那部分的粉红色区域,
GMT+8, 2025-10-6 07:29 , Processed in 0.012124 second(s), 3 queries , Gzip On, Redis On.
