查看: 5749|回复: 3
[讨论] 如何解决DC综合时有关时钟的warning
发表于 2012-5-23 12:38:00 | 显示全部楼层 |阅读模式
ll be used for delay calculations involving these nets. (TIM-134)
Warning: A non-unate path in clock network for clock 'CLK_WR_N'
from pin 'u_fifo/u_fifo_ctrl/u_dsp/U5/Y' is detected. (TIM-052)
Warning: A non-unate path in clock network for clock 'CLK_24M'
from pin 'u_clk_gen/U10/Y' is detected. (TIM-052)
Warning: A non-unate path in clock network for clock 'CLK_6M'
from pin 'u_clk_gen/U4/Y' is detected. (TIM-052)
Warning: A non-unate path in clock network for clock 'CLK_3M'
thanks
发表于 2012-5-23 15:05:29 | 显示全部楼层
你看help 里面,后面应该有解决的方式吧
发表于 2012-5-23 17:44:00 | 显示全部楼层
"non-unate path": 这个意思是说:根据输入端0->1 / 1->0的变化不能准确预测输出端的对应变化。所以你的“'u_fifo/u_fifo_ctrl/u_dsp/U5”, “'u_clk_gen/U10/”等应该不是一些简单的cell(如:AND, NOR),可能是latch/AIO/OAI等。
这个会导致什么问题,不是一两句话能说清楚的。
发表于 2012-5-23 21:09:18 | 显示全部楼层
直接在dc_shell里敲man TIM-052,它会有详细的解释,并告诉你该怎么做。
GMT+8, 2025-12-30 03:24 , Processed in 0.019869 second(s), 5 queries , Gzip On, Redis On.
