楼主: wapoca
[求助] 如何提取CDL时让电阻例化?
发表于 2012-5-6 19:33:21 | 显示全部楼层
回复 10# wapoca
    ...没坐过,咋知道
发表于 2012-5-7 13:18:20 | 显示全部楼层
Step 1: check (and try) if you get to generate correct netlsit from hspiceD views. -> You already mentioned your library did not have hspiceD views.
Alternative: use a (sed/awk/perl) script to post-process the CDL netlist.
    RGPS_1 net1 net2 $[RGPNC] $W=1u $L=10u
In your specific case, since you only need to post-process the resistor netlist format, it can be done by a fairly simple "sed" script.
Contents of the sed script (for instance, let me call it raw.sed) is as follows:
   s/\$\[//
   s/\]//
   s/\$//g
Excecute the following command under Linux:
   sed -f raw.sed YourNetlistFileName > raw.out
, where YourNetlistFileName is the name of original netlist file.
Check and see if the processed netlist in raw.out has the format you need.
Good luck!
 楼主| 发表于 2012-5-7 17:00:51 | 显示全部楼层
回复 12# fhchen2002
Thank you for your sharing.But i dont want to modify my netlist manully everytime.
do you have any other method?
Thanks
发表于 2012-5-8 12:48:41 | 显示全部楼层
回复 13# wapoca
This is not manual editing.
This automation is executed by (Unix/Linux) shell script.
GMT+8, 2025-12-20 17:18 , Processed in 0.013071 second(s), 4 queries , Gzip On, Redis On.
