查看: 8395|回复: 14
[求助] icc 读入verilog网表错误
发表于 2012-5-3 15:20:44 | 显示全部楼层 |阅读模式
icc读入verilog后出现Module 'DFFRHQX1' is not defined这样的错误,使用的库是论坛上http://bbs.eetop.cn/viewthread.php?tid=301894&highlight=tluplus
发表于 2012-5-3 15:29:22 | 显示全部楼层
直接打开lib看看有没有
或者report_lib
 楼主| 发表于 2012-5-3 15:30:54 | 显示全部楼层
回复 2# 陈涛
    我打开看过了,有这个单元啊。
发表于 2012-5-3 15:36:32 | 显示全部楼层
那就检查search_path, link_library, target_library
还有,你能保证lib和db是一致的吗?网上乱转的东西,多检查下
 楼主| 发表于 2012-5-3 15:39:09 | 显示全部楼层
回复 4# 陈涛
    嗯,我再试试,谢谢版主,,,
 楼主| 发表于 2012-5-3 16:11:35 | 显示全部楼层
回复 4# 陈涛
    我换了一个库,icc可以读入verilog网表了,
    我创建mw库时出现了下面的warning,这个对以后的操作有影响么?
    icc_shell> create_mw_lib  -technology /home/mikiah/smic/smic018/smic018logic/aci/sc-x/apollo/tf/smic18_6lm.tf -mw_reference_library {/home/mikiah/smic/smic018/smic018logic/aci/sc-x/apollo/smic18} -bus_naming_style {[%d]}  -open  ZDVC001.mw
Start to load technology file /home/mikiah/smic/smic018/smic018logic/aci/sc-x/apollo/tf/smic18_6lm.tf.
Warning: ContactCode 'CONT1' is missing the attribute 'unitMinResistance'. (line 480) (TFCHK-014)
Warning: ContactCode 'CONT1' is missing the attribute 'unitNomResistance'. (line 480) (TFCHK-014)
Warning: ContactCode 'CONT1' is missing the attribute 'unitMaxResistance'. (line 480) (TFCHK-014)
Warning: Cut layer 'VIA12' has a non-cross primary default ContactCode 'via1'. (line 498) (TFCHK-092)
Warning: Cut layer 'VIA23' has a non-cross primary default ContactCode 'via2'. (line 516) (TFCHK-092)
Warning: Cut layer 'VIA34' has a non-cross primary default ContactCode 'via3'. (line 534) (TFCHK-092)
Warning: Cut layer 'VIA45' has a non-cross primary default ContactCode 'via4'. (line 552) (TFCHK-092)
Warning: Layer 'METAL1' has a pitch 0.56 that does not match the recommended wire-to-via pitch 0.535 or 0.485. (TFCHK-049)
Warning: Layer 'METAL2' has a pitch 0.66 that does not match the recommended wire-to-via pitch 0.61 or 0.56. (TFCHK-049)
Warning: Layer 'METAL4' has a pitch 0.66 that does not match the recommended wire-to-via pitch 0.61 or 0.56. (TFCHK-049)
Warning: Layer 'METAL3' has a pitch 0.56 that does not match the doubled pitch 1.12 or tripled pitch 1.68. (TFCHK-050)
Warning: Layer 'METAL4' has a pitch 0.66 that does not match the doubled pitch 1.32 or tripled pitch 1.98. (TFCHK-050)
Warning: Layer 'METAL5' has a pitch 0.61 that does not match the doubled pitch 1.12 or tripled pitch 1.68. (TFCHK-050)
Warning: Layer 'METAL6' has a pitch 0.95 that does not match the doubled pitch 1.32 or tripled pitch 1.98. (TFCHK-050)
Technology file /home/mikiah/smic/smic018/smic018logic/aci/sc-x/apollo/tf/smic18_6lm.tf has been loaded successfully.
{ZDVC001.mw}
发表于 2012-7-17 15:23:32 | 显示全部楼层
回复 6# mikiahmikiah
    楼主后来换的库能发我一下吗?我也是用我现在的库,出现跟你最开始一样的问题,我想换个库试试,看是不是我的库的问题
  邮箱 06214038@bjtu.edu.cn  不胜感激呀~~
发表于 2012-9-14 11:01:30 | 显示全部楼层
楼主,能把你的库发给我吗?现在也碰到同样问题了!邮箱 641602698@qq.com!十分感谢!
发表于 2012-9-26 17:46:34 | 显示全部楼层
回复 6# mikiahmikiah
   问题是否解决 ,我也遇到这个问题了  感谢楼主啊!!
 楼主| 发表于 2012-9-26 19:10:18 | 显示全部楼层
回复 9# fhy420462303
    没有哦。。
GMT+8, 2025-10-8 19:29 , Processed in 0.022803 second(s), 5 queries , Gzip On, Redis On.
