查看: 5628|回复: 2
[求助] MMSIM7.2 安装失败求助
发表于 2012-4-28 14:45:34 | 显示全部楼层 |阅读模式
安装环境,centos5.5  用SETUP.SH选择路径安装iscape之后,出现:None of the selected products were successfully installed.
run.txt文件是这样的:
InstallScape Installer version 03.71.p02 started by
    User: yk
    On Operating System (OS) = Linux
    OS Version = 2.6.18-194.el5
    OS Architecture = i386
    At:20120428_121032
An SDL file is specified..../home/eda/MMSIM07.20.109_lnx86.Base/CDROM1:::/home/yk/MMSIM7
Setting  SDL file in....com.khanpur.installer.gui.InstallerUINoSplash
In setSDLFile: the wizard view IS null
Starting InstallScape Installer in wizard mode
InstallerUINoSplash.showWizard
InstallScape Installer (Wizard Mode) - 03.71.p02
com.khanpur.installer.gui.wizard.ISWizardView:Instantiated with arg InstallScape(TM) Wizard
com.khanpur.installer.gui.wizard.ISWizardView:initialize
In showWizard: the SDL file is not null - /home/eda/MMSIM07.20.109_lnx86.Base/CDROM1:::/home/yk/MMSIM7
NON-NULL
后面还有很长就不贴了,类似这样的:
/home/yk/MMSIM7/installData/MMSIM72_lnx86/iscape_env
Content of environemt file:
IS_LOG=/home/yk/.iscape/iscape_logs/20120428_121032_scripts.txt; export IS_LOG
IS_SOURCELOCATION=/home/eda/MMSIM07.20.109_lnx86.Base/CDROM1; export IS_SOURCELOCATION
IS_PROD_PLAT=lnx86; export IS_PROD_PLAT
IS_REL=MMSIM72; export IS_REL
IS_KFL_FILE=/home/yk/MMSIM7/installData/shared/kmmsim_confData.kfl; export IS_KFL_FILE
IS_INSTALLDIR=/home/yk/MMSIM7; export IS_INSTALLDIR
IS_USEGUI=true; export IS_USEGUI
IS_PLAT=lnx86; export IS_PLAT
Writing environment file: /home/yk/MMSIM7/install/tmp/iscape_env
Unpacking: DisplayName - /kitsmmsim_confData07.20-p001.t.Z
/bin/sh /home/yk/MMSIM7/install/tmp/sltar.sh "/home/eda/MMSIM07.20.109_lnx86.Base/CDROM1/kits/mmsim_confData07.20-p001.t.Z" mmsim_confData07.20-p001
The Output is
Begining output from /bin/sh /home/yk/MMSIM7/install/tmp/sltar.sh "/home/eda/MMSIM07.20.109_lnx86.Base/CDROM1/kits/mmsim_confData07.20-p001.t.Z" mmsim_confData07.20-p001
    Installing component (CDROM): mmsim_confData 07.20-p001
    From: /home/eda/MMSIM07.20.109_lnx86.Base/CDROM1/kits/mmsim_confData07.20-p001.t.Z
   To:/home/yk/MMSIM7
    Installed Component: mmsim_confData 07.20-p001
Writing environment file: /home/yk/MMSIM7/installData/MMSIM72_lnx86/iscape_env
IS_KFL_FILE=/home/yk/MMSIM7/installData/shared/kultrasimDoc.kfl; export IS_KFL_FILE
哪位高人告诉我怎么回事啊?安装之前还要做些什么?万分感谢!
发表于 2012-10-30 07:07:10 | 显示全部楼层
我用iscape4装的,linux版本比你还新,都没问题
发表于 2012-12-11 15:54:09 | 显示全部楼层
要分享这种主题
GMT+8, 2025-12-16 18:02 , Processed in 0.018480 second(s), 7 queries , Gzip On, Redis On.
