查看: 4663|回复: 6
[求助] Can I change ICC tie cell instance naming?
发表于 2012-4-27 16:33:34 | 显示全部楼层 |阅读模式
I using ICC command "connect_tie_cells" to do tie cell inserting for tie-off nets.But, the result for tie-cell instance name is not good.
ex.  TIE0 \TIE0!U19( .O( \TIE0!U19_net ));
Can I specify the naming rule for those inserted tie cells?
my full command:
derive_pg_connection
derive_pg_connection -power_net $MW_POWER_NET -ground_net $MW_GROUND_NET -tie
connect_tie_cells -tie_high_lib_cell $TIE_HIGH_CELL -tie_low_lib_cell $TIE_LOW_CELL \
-tie_high_port_name $TIE_HIGH_PORT \
-tie_low_port_name  $TIE_LOW_PORT \
-max_fanout 5 \
-max_wirelength 20\
-objects [get_cells  "spares_icc*" ] \
-obj_type cell_inst  \
-incremental true
PS. the command "connect_tie_cells" seems doesn't work for "ANTENNA" cell.
      IS it true?
     or my above command has something wrong?
发表于 2012-4-28 06:24:55 | 显示全部楼层
change_names -rules verilog -hier  before write_verilog out ,
connect_tie_cells has no relations with antenna cells,
发表于 2012-4-28 23:15:54 | 显示全部楼层
实在不行,用set_name 吧,可以改instance name的
 楼主| 发表于 2012-4-30 10:27:36 | 显示全部楼层
Hi icfbicfb,
Thank you, the command "change_names" is work.
发表于 2012-4-30 17:52:18 | 显示全部楼层
 楼主| 发表于 2012-5-2 09:54:59 | 显示全部楼层
RE: Can I change ICC tie cell instance naming? (已解決)
发表于 2012-5-30 17:26:49 | 显示全部楼层
那么astro下,这个问题要怎么解决呢?
GMT+8, 2025-12-20 13:01 , Processed in 0.018194 second(s), 7 queries , Gzip On, Redis On.
