查看: 2457|回复: 6
[求助] 麻烦各位帮看下顶层VHDL程序哪错了,本人初学者
发表于 2012-4-26 17:24:08 | 显示全部楼层 |阅读模式
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
--顶层结构
ENTITY FreqMeter IS
   PORT(
      input   :IN STD_LOGIC;
      clock   :IN STD_LOGIC;
      display  :OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
      dp      :OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
      sample  :OUT STD_LOGIC
END FreqMeter;
ARCHITECTURE FreqMeter_arch OF FreqMeter IS
   COMPONENT ClockGen
      PORT(
         clkHF  :IN STD_LOGIC;
         clk10  :OUT STD_LOGIC;
         clk100 :OUT STD_LOGIC;
         clk1k  :OUT STD_LOGIC
   END COMPONENT;
   COMPONENT Center
      PORT(
        clk10   :IN STD_LOGIC;
        digitalHF:IN STD_LOGIC_VECTOR(31 DOWNTO 0);
        digitalLF:IN STD_LOGIC_VECTOR(11 DOWNTO 0);
        fr_high  :IN STD_LOGIC;
        fr_low   :IN STD_LOGIC;
        fr_vlow  : IN STD_LOGIC;
        busy     :IN STD_LOGIC;
        sample   :OUT STD_LOGIC;
        set       :BUFFER STD_LOGIC;
        clr       :BUFFER STD_LOGIC;
        ce       :BUFFER STD_LOGIC
   END COMPONENT;
   COMPONENT HiCnt
      PORT(
         enable :IN STD_LOGIC;
         clr    :IN STD_LOGIC;
         digital :BUFFER STD_LOGIC_VECTOR(31 DOWNTO 0)
   END COMPONENT;
   COMPONENT Divide
      PORT(
         set     :IN STD_LOGIC;
         clk     :IN STD_LOGIC;
         count   :IN STD_LOGIC_VECTOR(9 DOWNTO 0);
         digital  :OUT STD_LOGIC_VECTOR(9 DOWNTO 0)
   END COMPONENT;
   COMPONENT LowCnt
      PORT(
      clk1k  :IN STD_LOGIC;
      clk100 :IN STD_LOGIC;
      clr    :IN STD_LOGIC;
      count  :OUT STD_LOGIC_VECTOR(9 DOWNTO 0);
      busy   :BUFFER STD_LOGIC;
      fr_high :BUFFER STD_LOGIC;
      fr_low  :BUFFER STD_LOGIC;
      fr_vlow : BUFFER STD_LOGIC
   END COMPONENT;
   SIGNAL clk10,clk100,clk1k:STD_LOGIC;
   SIGNAL ce,clr,ser,busy:STD_LOGIC;
   SIGNAL fr_high,fr_low,fr_vlow:STD_LOGIC;
   SIGNAL count:STD_LOGIC_VECTOR(9 DOWNTO 0);
   SIGNAL digitalHF:STD_LOGIC_VECTOR(31 DOWNTO 0);
   SIGNAL digitalLF:STD_LOGIC_VECTOR(11 DOWNTO 0);
BEGIN
   u1: ClockGen PORT MAP (clock,clk10,clk100,clk1k);
   u2: Center PORT MAP (clk10,digitalHF,digitalLF,fr_high,fr_low,
                      fr_vlow,busy,display,dp,sample,set,clr,ce);
   u3: HiCnt PORT MAP (input,ce,clr,digitalHF);
   u4: LowCnt PORT MAP (input,clk1k,clk100,clk10,
                         clr,count,busy,fr_high,fr_low,fr_vlow);
   u5: Divide PORT MAP (set,clock,count,digitalLF);
END FreqMeter_arch;
错误提示80)bject "set" is used but not declarer
 楼主| 发表于 2012-4-26 17:27:28 | 显示全部楼层
错误  object "set" is used but not declarer
 楼主| 发表于 2012-4-26 19:45:53 | 显示全部楼层
求帮助了!!!
发表于 2012-5-2 17:33:29 | 显示全部楼层
定义一个set 信号就可以了
SIGNAL set :STD_LOGIC;
发表于 2012-5-5 22:49:14 | 显示全部楼层
使用了set信号,但是没有定义该信号
发表于 2012-5-9 00:30:06 | 显示全部楼层
对啊,需要在实体里定义一个set信号啊
发表于 2012-5-23 17:49:14 | 显示全部楼层
你的信号声明里面有个ser信号,声明了但没有使用,估计是声明时写错了……
GMT+8, 2025-12-22 20:50 , Processed in 0.021500 second(s), 7 queries , Gzip On, Redis On.
