楼主: bob_haohao
[求助] 请教VCS和verdi怎么联合使用
发表于 2015-11-3 11:04:10 | 显示全部楼层
休息休息吧
发表于 2015-11-7 15:55:22 | 显示全部楼层
不错哦!!!
发表于 2016-4-18 10:58:50 | 显示全部楼层
还是有人认真回答的
发表于 2016-4-20 10:53:49 | 显示全部楼层
$fsdbDumpvars
Description
To dump signal-value-change information to the FSDB file instead of the VCD
file. The syntax usage of this task is exactly the same as for $dumpvars.
Syntaxes
$fsdbDumpvars;
$fsdbDumpvars([level] [, module | var]*);
$fsdbDumpvars("level=", level [, module | var]*);
$fsdbDumpvars("+no_functions" | ["level=", level] [, module |
var]*);
Arguments
<level>:
Specifies how may levels of the hierarchy to dump for the subsequent
scopes. If the subsequent arguments are variables, only these variables will
be dumped. If you want to specify this level argument as variable type, you
have specify the first argument as string literal level= and the second
argument as level argument.
<module | var>:
This definition gives either the module scope or variables that specify the
objects to dump.
Examples
$fsdbDumpvars;
Dump all variables in the module that contains this statement and in all
module instances below this module.
$fsdbDumpvars(0, system);
Dump all variables in the system module and in all module instances below
system.
$fsdbDumpvars(1, system.i_cpu, system.i_CPU.i_PCU.net1);
462 Debussy Command Reference
Dump all the variables in scope system.i_cpu and the variable
system.i_CPU.i_PCU.net1.
$fsdbDumpvars("level=", level_reg, system);
it up to the depth that level_reg variable indicates.
If you specify +no_functions string option in $fsdbDumpvars call, the functions
in the design will not be dumped. You can do it with either
$fsdbDumpvars("+no_functions","level=",0, system);
or
$fsdbDumpvars(0, "+no_functions",system);
The $fsdbDumpvars call dumps all children and descent scopes except
functions under the scope system.
发表于 2019-2-19 12:23:06 | 显示全部楼层
thanks
GMT+8, 2025-12-30 10:00 , Processed in 0.017459 second(s), 4 queries , Gzip On, Redis On.
