查看: 4008|回复: 6
[讨论] 为何要使用nanosim
发表于 2012-4-11 11:38:51 | 显示全部楼层 |阅读模式
SOC设计后面的阶段,导出sdf进行PT仿真不可以signoff吗?
和nanosim有何区别?
发表于 2012-4-11 15:52:38 | 显示全部楼层
Take nanosim as a fast spice ( but may not as accurate as spice ). Though we say "fast", it's still slow compared to gate level simulation. Use or not according to project need.
 楼主| 发表于 2012-4-11 16:20:10 | 显示全部楼层
回复 3# lmcon223
同感。
另外就是我感觉,PT + 后端sdf 是gate level级,而 nanosim 是 Post layout transistor-level 级,而且可以加vector,查看power和SI 方面的信息。但就是想知道nanosim是不是一定要跑,如果项目时间紧的话,是不是就跳过去了。
发表于 2012-4-11 22:40:32 | 显示全部楼层
回复 4# morrisgu
    For mixed-signal design, if the interface or interference behavior of analog/custom block can be signoff-ed alone, that dramatically reduces the need of full chip transistor level simulation of function.
    But for the dynamic power analysis of full chip, especially for real functional patterns, nanosim or similar tools count.
发表于 2013-5-21 17:42:59 | 显示全部楼层
回复 5# lmcon223
   nanosim ultrasim 各有什么优缺点?
发表于 2013-5-22 11:12:26 | 显示全部楼层
支持3楼 4楼!
GMT+8, 2025-12-18 18:38 , Processed in 0.020755 second(s), 4 queries , Gzip On, Redis On.
