查看: 6142|回复: 7
laker patch 201106
发表于 2012-4-8 19:37:13 | 显示全部楼层 |阅读模式
出现了一下问题,高手能帮忙解决一下吗?
logDir = /Laker/platform/LINUX/bin/lakerLog/laker_04_08_19_31_7507
Open default display file = /Laker/etc/default.dsp
Laker - Custom Layout Automation System, 2011.06 32-bit (Linux) 08/18/2011
Copyright (C) 1999 - 2011 by SpringSoft, Inc.
All Rights Reserved.
www.springsoft.com
This computer program constitutes or contains trade secrets and confidential
information of SpringSoft Inc. or its licensors. This computer program is
protected by copyright law and international treaties.
Display :0.0 ==> Current mode : TrueColor
   The PseudoColor mode is not available under current setting. Switch to use TrueColor mode.
   *** Limitation: Blinking is not supported under TrueColor mode.
fontPath(SPS_FONT_PATH) = /Laker/TTFont
*ERROR* License checking failed, or the maximum number of licensed users has been reached. Use laker -licdebug for more information.
 楼主| 发表于 2012-4-9 11:11:24 | 显示全部楼层
有好人吗?
发表于 2012-4-13 11:03:27 | 显示全部楼层
license问题
估计你使用的patch可能不完美吧。
看你发的几个帖子,帮你下。
pm我留下邮箱及mac
 楼主| 发表于 2012-4-16 12:42:46 | 显示全部楼层
回复 3# canxye
    feihu1236@126.com   谢谢,我用的是 虚拟机
发表于 2012-4-20 11:30:20 | 显示全部楼层
If u had patched, try
unsetenv      LM_LICENSE_FILE
 楼主| 发表于 2012-5-2 18:09:16 | 显示全部楼层
回复 5# teatime77
   谢谢
发表于 2015-2-3 22:08:35 | 显示全部楼层
no license
发表于 2015-9-22 14:58:36 | 显示全部楼层
GMT+8, 2025-12-18 22:26 , Processed in 0.024736 second(s), 6 queries , Gzip On, Redis On.
