查看: 7598|回复: 10
[求助] 关于ocean仿真问题~
发表于 2012-4-5 23:38:35 | 显示全部楼层 |阅读模式
在ADE跑完ac,dc,stb仿真后,然后我就save scripts了,但是即便是用这个刚保存的scripts,打开ocean后,用load命令打开文件,也会出现
The directory you specified does not contain valid PSF results. Please check the line for typographical errors or look in the directory for a logFile and PSF result files.
这是怎么回事有人知道吗,谢了~
发表于 2012-4-6 08:52:07 | 显示全部楼层
把你的script贴上来
 楼主| 发表于 2012-4-6 11:01:21 | 显示全部楼层
回复 2# greatqs
   ocnWaveformTool( 'wavescan )simulator( 'spectre )
design(
"/export/home/maliangyi/simulation/floa_ocean/spectre/schematic/netlist/netlist")
resultsDir( "/export/home/maliangyi/simulation/floa_ocean/spectre/schematic" )
p=outfile("./pre_simulation.txt" "w")
fprintf(p,"%s\t" "ac_gain(dB)")
fprintf(p,"%s\t" "BandWidth(MHz)")
fprintf(p,"%s\n" "PM(degree)")
i=1.0
sel_12M_t=list(0,1.8)
sel_1_t=list(0,1.8)
sel_2_t=list(0,1.8)
sel_3_t=list(0,1.8)
sel_4_t=list(0,1.8)
sel_5_t=list(01.8)
sel_6_t=list(0,1.8)
sel_7_t=list(0,1.8)
sel_8_t=list(0,1.8)
sel_9_t=list(0,1.8)
sel_10_t=list(0,1.8)
sel_11_t=list(0,1.8)
sel_12_t=list(0,1.8)
sel_13_t=list(0,1.8)
sel_14_t=list(0,1.8)
sel_15_t=list(0,1.8)
sel_16_t=list(0,1.8)
sel_17_t=list(0,1.8)
sel_18_t=list(0,1.8)
sel_19_t=list(0,1.8)
sel_20_t=list(0,1.8)
sel_21_t=list(0,1.8)
sel_22_t=list(0,1.8)
sel_23_t=list(0,1.8)
sel_24_t=list(0,1.8)
sel_25_t=list(0,1.8)
sel_26_t=list(0,1.8)
sel_27_t=list(0,1.8)
foreach(sel_12M sel_12M_t
  foreach(sel_27 sel_1_t
  foreach(sel_26 sel_2_t
  foreach(sel_25 sel_1_t
  foreach(sel_24 sel_1_t
  foreach(sel_23 sel_1_t
  foreach(sel_22 sel_1_t
  foreach(sel_21 sel_1_t
  foreach(sel_20 sel_1_t
  foreach(sel_19 sel_1_t
  foreach(sel_18 sel_1_t
  foreach(sel_17 sel_1_t
  foreach(sel_16 sel_1_t
  foreach(sel_15 sel_1_t
  foreach(sel_14 sel_1_t
  foreach(sel_13 sel_1_t
  foreach(sel_12 sel_1_t
  foreach(sel_11 sel_1_t
  foreach(sel_10 sel_1_t
  foreach(sel_9 sel_1_t
  foreach(sel_8 sel_2_t
  foreach(sel_7 sel_2_t
  foreach(sel_6 sel_2_t
  foreach(sel_5 sel_2_t
  foreach(sel_4 sel_2_t
  foreach(sel_3 sel_2_t
  foreach(sel_2 sel_2_t
  foreach(sel_1 sel_2_t
modelFile(
    list("/export/home/maliangyi/m.scs" "tt")
analysis('ac ?start "1"  ?stop "1G"  )
analysis('dc ?saveOppoint t  )
analysis('stb ?start "1"  ?stop "1G"  ?probe "/I3/I175/vinj"  )
desVar(
  "v_t" 45u
desVar(
  "sel_12M" sel_12M
desVar(
  "sel9" sel_9
desVar(
  "sel8" sel_8
desVar(
  "sel7" sel_7
desVar(
  "sel6" sel_6
desVar(
  "sel5" sel_5
desVar(
  "sel4" sel_4
desVar(
  "sel3" sel_3
desVar(
  "sel24" sel_24        )
desVar(
  "sel23" sel_23        )
desVar(
  "sel22" sel_22
desVar(
  "sel21" sel_21
desVar(
  "sel20" sel_20
desVar(
  "sel2"  sel_2
desVar(
  "sel19" sel_19
desVar(
  "sel18" sel_18
desVar(
  "sel17" sel_17
desVar(
  "sel16" sel_16
desVar(
  "sel15" sel_15
desVar(
  "sel14" sel_14
desVar(
  "sel13" sel_13
desVar(
  "sel12" sel_12
desVar(
  "sel11" sel_11
desVar(
  "sel10" sel_10
desVar(
  "sel1"  sel_1
desVar(
  "f_t" 12M
temp( 27 )
run()
BW = bandwidth((v("/vout+" ?result "ac-ac") - v("/vout-" ?result "ac-ac")) 3 "band")
Phase\ Margin = getData("phaseMargin" ?result "stb_margin")
ac_gain\@1MHz = value(dB20((v("/vout+" ?result "ac-ac") - v("/vout-" ?result "ac-ac"))) 1000000)
fprintf(p,"%f\t" ac_gain\@1MHz)
fprintf(p,"%f\t" BW)
fprintf(p,"%f\n" Phase\ Margin)
printf("===============================================\n")
printf("!!!!!!!!!!!!!!%f loops have done!!!!!!!!!!\n" i)
i=i+1
if(i>76 then
    close(p)
   printf("===============!!!!!!!!!!!!!!!!!!DONE!!!!!!!!!!!!!!!!!!===================\n")
在上面那个提示错误上,还有两行,不知道有没有用
Delete psf data in /export/home/maliangyi/simulation/floa_ocean/spectre/schematic/psf.
Cannot start up spectre.
我感觉是不是因为开头有什么原因错了,直接就没有开始仿真。
还有两句error提示
*Error* difference: can't handle (nil - nil)
*Error* load: error while loading file - "/export/home/maliangyi/Ocean/oceanScript_2.ocn"
谢谢了~
发表于 2014-4-15 20:14:02 | 显示全部楼层
学习中!!!
发表于 2014-8-26 06:58:58 | 显示全部楼层
我也才开始学习写ocean 脚本。
发表于 2015-7-21 21:13:17 | 显示全部楼层
正在学习
发表于 2015-9-24 13:41:22 | 显示全部楼层
我也遇到同样的问题 求解
发表于 2016-3-15 19:24:15 | 显示全部楼层
mark  一下
发表于 2016-3-15 21:00:36 | 显示全部楼层
建议删掉 ocnWaveformTool( 'wavescan )试一下;还有就是只跑stb仿真后试一下 (前提都是你的ADE仿真成功)
发表于 2016-8-25 15:10:59 | 显示全部楼层
ocean 脚本的学习资料谁有?求赐
GMT+8, 2025-12-28 22:29 , Processed in 0.033968 second(s), 6 queries , Gzip On, Redis On.
