查看: 2413|回复: 2
An excellent site for locating every web server and IP address on the earth
发表于 2012-4-2 22:01:56 | 显示全部楼层 |阅读模式
Below is a good site that shows the exact location of every IP address (web servers and also every individual IP addresses) on the earth.
For getting IP addresses open a console window in the windows (by simply typing cmd command in the run) and type below command (we want to get for example IP address for cadence.com):
ping cadence.com
if you type above address you will get following IP:
192.203.56.67
Then copy the above address and go to the site that is in link.rar. When you open this site you will be informed about your using IP address and also your ISP server location. In the field paste copied IP address that you have got for cadence.com. You will see information like below picture, then you can zoom it and also drag the human to your favorite location for seeing streets and building etc. It is so good. By doing this you will get any information about any server on the planet:
link.rar
100 Bytes, 下载次数: 14 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2012-4-2 22:15:43 | 显示全部楼层
wow that's wonderfull
发表于 2014-11-1 13:27:12 | 显示全部楼层
下来试试
GMT+8, 2025-12-16 09:53 , Processed in 0.015266 second(s), 4 queries , Gzip On, Redis On.
