楼主: wt_ckt
[资料] Hotfix_ASSURA04.12.008-614_lnx86
发表于 2015-11-10 11:37:15 | 显示全部楼层
thanks
发表于 2015-11-17 11:29:08 | 显示全部楼层
assura
发表于 2015-11-23 21:17:39 | 显示全部楼层
为什么不放网盘?骗积分吗?
发表于 2015-12-7 09:46:07 | 显示全部楼层
Thx!!
发表于 2015-12-30 18:18:14 | 显示全部楼层
回复 1# wt_ckt
   Can you share ASSURA04.14.124-616 hotfix ?
发表于 2016-1-10 12:40:28 | 显示全部楼层
感谢分享
发表于 2016-1-20 15:29:14 | 显示全部楼层
回复 3# wt_ckt
谢谢分享!!
发表于 2016-2-27 10:03:50 | 显示全部楼层
不错,下载看看
发表于 2016-3-10 17:35:28 | 显示全部楼层
Hi everybody,
I have a problem with the Assura hotfix.
IC610 installed sucessfully and it is working in 32 bit Ubuntu 10. After that, Assura installed with the patch.
While loading Assura in Cadence Layout Suite L, I got the mesage below.
/home/kazim/eda/ic610/tools/lib/libgcc_s.so.1: version `GCC_4.2.0 'not found (required by /usr/lib/libstdc++.so.6)
So, I need to have GCC_4.2.0 Version (GNU Compiler Collection) installed in the Machine. Other versions MUST be removed first and then the Package for GCC_4.2.0 MUST be installed manually. It is Hard Process to do it.
Is there any way to run Assura correctly. Pictures are below.
Screen_shot1
Screen_shot1
screen_shot2
screen_shot2
发表于 2016-3-11 22:16:20 | 显示全部楼层
回复 104# wafer_2013
   Do not worry about that. I solved the problem, link is below. Just you need to do ln -sf /lib/libgcc_s.so.1 $CDS_ROOT/tools.lnx86/lib/libgcc_s.so.1
http://bbs.eetop.cn/thread-343674-1-1.html
GMT+8, 2025-12-30 11:33 , Processed in 0.025264 second(s), 6 queries , Gzip On, Redis On.
