查看: 7251|回复: 16
[资料] 发布ADI rf sim系统参数和模块spec计算软件
发表于 2012-4-1 00:08:47 | 显示全部楼层 |阅读模式
ADIsimRF is an easy-to-use RF signal chain calculator. ADIsimRF_Rev_1_6_for_Win7_and_Vista.zip (14.28 MB , 下载次数: 704 ) [attaADIsimRF is an easy-to-use RF signal chain calculator. Cascaded Gain, Noise Figure, IP3 and P1dB as well as total power consumption are calculated. The number of stages can be varied up to a maximum of 15. Additional stages can be inserted at any point in the signal chain and individual stages can be temporarily disabled or deleted. The calculator can be switched between Transmit Mode and Receive Mode where calculations are presented output-referred and input-referred respectively.
ADIsimRF contains an embedded database of most of ADI's RF components. Standard components can be easily accessed using pull-down menus. Device data (IP3, P1dB, Gain and Noise Figure) are stored at various frequency increments. For variable gain devices, data are also stored at various gain increments. Data from the internal database can be overwritten in the calculator panel and custom devices can be created and stored in the database. To assist in the selection of components, component selection tables are also included. ADIsimRF also includes device models from third party vendors for approximately 50 baluns and SAW filters.
System Requirements: Windows XP, Windows Vista or Windows 7ch]434100[/attach]
发表于 2012-7-18 11:00:04 | 显示全部楼层
不支持xp?
发表于 2015-9-7 20:07:25 | 显示全部楼层
好东西哇
发表于 2015-9-7 21:11:21 | 显示全部楼层
see see
发表于 2015-9-8 08:22:44 | 显示全部楼层
发表于 2015-11-16 09:57:21 | 显示全部楼层
感谢楼主正在安装
发表于 2015-11-20 14:16:44 | 显示全部楼层
ADI rf sim
发表于 2016-11-26 16:51:29 | 显示全部楼层
十分感谢
发表于 2017-3-8 15:19:10 | 显示全部楼层
回复 1# amswu
   GOOD   GOOD
发表于 2017-3-12 23:20:52 | 显示全部楼层
多谢。。。。
GMT+8, 2025-10-6 16:04 , Processed in 0.024284 second(s), 8 queries , Gzip On, Redis On.
