查看: 2489|回复: 1
[招聘] Cadence SH招聘高级软件开发工程师(要求博士学位)
发表于 2012-3-26 17:04:22 | 显示全部楼层 |阅读模式
Cadence上海研发团队正在招聘具有博士学位的高级软件研发工程师,应届生和有经验者均可投递,有意者请将简历投递至cecilyl@cadence.com
1. Senior Software Engineer for Floor plan
     Position Description:
1. The candidate will be a member of the Encounter floorplan team in Shanghai, to work on the development and maintenance of manual Floorplan project.
2. The responsibilities include the development of new features and products, and support other teams in Encounter product lines.
3. The candidate must be comfortable working with existing code as well as developing new functionality to address new requirements, and be working closely with local/remote team members, and be also strong technical support to team.
     Requirements:
1. Candidate must be an expert in software engineering methods and committed to high quality of development work.
2. The individual must be team-oriented, possess good communication skills, self-motivated, able to work independently and working with a team from multiple remote sites.
3. Candidate must be able to develop detailed technical specification as well as the ability to scope efforts required.
4. The candidate must be also smart to capture new EDA technologies, and switch among different areas successfully.
5. Advanced developing and debugging software in  UNIX & LINUX environments, familiar with gnu c/c++, gdb etc..
6. Strong problem-solving, architecture, algorithmic.
7. Familiar with interpreted language such as TCL is a plus.
8. Knowledge of Digital Physical Design flow such as Floorplan/Placement/Routing/CTS is a plus.
2.  Senior Software Engineer for Encounter Hier Solution Team
1. The candidate will be a member of the Encounter Hier Solution team in Shanghai, to work on the development and maintenance of Hier Solution project.
2. The responsibilities include development of new features and products, and support other teams in Encounter product lines.
     Requirements:
8. Knowledge of Timing analysis is a plus.
3.  Senior Software Engineer for CTS
1.  R&D engineer to do the clock tree synthesis related works (product maintain, software development, design flow improvement etc.)
     Requirements:
1. MS or PhD in EE/CS etc.
2. Excellent programming skills (C/C++, script)
3. The following background is preferred: EDA, IC physical design, CTS, Timing analysis, 4. Optimization.
5. Good written and spoken English
6. Good communication skills and be able to work within a team.
4. (Sr.) Member of Technical Staff for distributed computing (Encounter)
1. The candidate will be responsible for the development and maintenance of distributed computing infrastructure of Encounter platform in Cadence.
Position Requirements:
1. MS or above in CS/EE with 3+ years of working experience or BS with 5+ years of working experience for Sr. Member of Technical Staff; MS or above in CS/EE or BS with 3+ years of working experience for Member of Technical Staff
2. Programming skill on Linux/Unix platform is must.
3. Strong C/C++ coding skill.
4.  Deep understanding on Linux/Unix OS
5. Parallel computing programming skill is strongly expected.
6. Tcl programming skill is a plus
7. EDA software development experience is a plus.
8. Strong desires to learn and explore new technologies and is able to demonstrate good analysis and problem solving skills
9. Good English communication skill, both oral and written.
Ph.D is a plus.
 楼主| 发表于 2012-4-1 14:34:23 | 显示全部楼层
持续招聘中!
GMT+8, 2025-12-21 07:07 , Processed in 0.012188 second(s), 3 queries , Gzip On, Redis On.
