查看: 3920|回复: 3
[求助] 关于Perl的 -- push命令 (已解决)
发表于 2012-3-13 15:05:00 | 显示全部楼层 |阅读模式
程序:
#!/usr/bin/perl -w
foreach (qw/ 1 2 3 4 5 6/) {
   push @aa, "$_\n" ;
print "@aa" ;
结果:
1
2
3
4
5
6
有没有人知道,为什么从第二行开始,前面都会有一个空格。如果想滤除这个空格,需要做什么?
发表于 2012-3-13 15:55:34 | 显示全部楼层
数组在“”中内插的分隔符吧。
可以看perl的文档:
$LIST_SEPARATOR
When an array or an array slice is interpolated into a double-quoted string or a similar context such as /.../, its elements are separated by this value. Default is a space. For example, this:
        print "The array is: @array\n";
is equivalent to this:
        print "The array is: " . join($", @array) . "\n";
Mnemonic: works in double-quoted context.
发表于 2012-4-17 14:56:17 | 显示全部楼层
把print "@aa"中的双引号去掉。
发表于 2020-5-16 09:43:44 | 显示全部楼层
thanks
GMT+8, 2025-12-22 05:54 , Processed in 0.025598 second(s), 5 queries , Gzip On, Redis On.
