查看: 2946|回复: 2
[求助] ovm virtual sequences求助
发表于 2012-3-12 12:45:36 | 显示全部楼层 |阅读模式
class simple_virt_seq extends ovm_sequence;
... // Constructor and OVM automation macros
// See “Creating and Adding a New Sequence” on page 82.
// A sequence from the cpu sequencer library
cpu_config_seq conf_seq;
// A sequence from the ethernet subsequencer library
eth_large_payload_seq frame_seq;
// A virtual sequence from this sequencer's library
random_traffic_virt_seq rand_virt_seq;
virtual task body();
// Invoke a sequence in the cpu subsequencer.
`ovm_do_on(conf_seq, p_sequencer.cpu_seqr)
// Invoke a sequence in the ethernet subsequencer.
`ovm_do_on(frame_seq, p_sequencer.eth_seqr)
// Invoke another virtual sequence in this sequencer.
`ovm_do(rand_virt_seq)
endtask : body
endclass : simple_virt_seq
上面的这段代码摘自OVM user guider,定义了一个ovm virtual sequence,但是可以在其中访问p_sequencer吗?类内部并没有例化这个组件啊?
user guider多次出现这种代码?表示不理解求高手指教。
发表于 2012-3-12 20:17:31 | 显示全部楼层
通过宏实现的,
`ovm_sequence_utils -> `ovm_declare_p_sequencer
 楼主| 发表于 2012-3-26 16:02:32 | 显示全部楼层
回复 2# whxqq
    谢谢,加你好友了,希望以后多指教。
GMT+8, 2025-12-24 18:01 , Processed in 0.017588 second(s), 5 queries , Gzip On, Redis On.
