查看: 3133|回复: 3
[原创] Optimizing Power-Save-Mode Performance in buck converter
发表于 2012-2-14 10:58:07 | 显示全部楼层 |阅读模式
Topic_5_Matzberger_Vaucourt (2).pdf (1.49 MB , 下载次数: 92 ) A paper introduce some ways which is used to Optimizing Power-Save-Mode Performance in Low-Power Synchronous Buck Converters in TI (Texas Instruments).
Brief:
Buck converters have become common place in a variety of applications where size and efficiency are
primary considerations. While basic converters operate with fixed-frequency, pulse-width modulation
(PWM), many low-power applications can benefit from the performance improvements of variablefrequency
or pulse-frequency modulation (PFM). This topic covers the operational differences between
PWM and PFM architectures, with detailed discussion about key parameters such as output ripple
voltage, quiescent current, and load-transient response. Also covered are PFM topologies that use single
threshold, dual threshold
发表于 2013-6-4 18:20:48 | 显示全部楼层
RE: Optimizing Power-Save-Mode Performance in buck converter [修改]
发表于 2016-3-19 10:49:35 | 显示全部楼层
发表于 2018-5-4 19:12:41 | 显示全部楼层
謝謝分享..好東西.
GMT+8, 2025-12-14 01:02 , Processed in 0.018841 second(s), 7 queries , Gzip On, Redis On.
