查看: 2492|回复: 0
[招聘] 【社会招聘】LSI上海Preamp Analog Mixed Signal Physical Design (Layout) Engineer
发表于 2012-2-10 13:14:32 | 显示全部楼层 |阅读模式
有意者,请将简历发至:Tracey.zheng@lsi.com
如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.
也可加我msn: zql975504@hotmail.com
或者微博啊:http://www.weibo.com/u/1752448637
1.
Job Description
LSI's Storage Peripherals Group is looking for an experienced IC physical design engineer to join the pre-amplifier design team. As a preamp physical design (layout) engineer you will work closely with circuit design to implement high-speed custom analog designs and develop mask layouts for customer products. You will join a cross-functional team responsible for developing leading edge high-speed magneto electronic read/write IC products that ultimately achieve high volume production
- Layout high speed analog and mixed-signal custom chips for the hard disk drive industry
- Work directly with a team of engineers to determine floor plan, routing and I/O requirements for preamp IC's
- Perform IC design rule and connectivity verification and drive products through mask release flows.
- Contribute to methodology improvements to increase layout and verification efficiency
Requirements/Qualifications (Education)
- Bachelor's degree in Electrical Engineering (or related field) or equivalent experience\Minimum three to five years experience in custom analog IC physical design
- Experience with schematic-driven layout, floor planning, chip level routing, design for manufacturing and design rule and connectivity verification is required
- Experience using Cadence Virtuoso XL and VCAR router preferred
- Familiarity with both analog and digital layout tools and flows, circuit design concepts and IC manufacturing processes desired
GMT+8, 2025-12-24 06:16 , Processed in 0.034909 second(s), 7 queries , Gzip On, Redis On.
