查看: 2222|回复: 0
[求助] 想請問各位前輩 大大一題設計OPA的考題
发表于 2012-2-8 11:20:41 | 显示全部楼层 |阅读模式
想請問各位前輩 大大一題設計的問題
Use ideal OPAs , switches , diodes , resistors , and capacitors to implement the circuits
satisfying the following equations , where vo is the output voltage
and vi , vi1 , vi2 , vi3 , vi4 are the input voltages.
Draw the Schematics of the circuits.
AND the equattion is vo=-2vi , if 5v>vi>0v ; vo=10v if vi>5v ; vo=0v if vi<0v
麻煩各位大大指導小弟 感謝了 ^^
GMT+8, 2025-12-18 02:32 , Processed in 0.013854 second(s), 6 queries , Gzip On, Redis On.
