想要在ADE环境下仿真一款芯片的性能(例如ADI的ADA4817),ADI给出的网表为:ADA4817.txt
我在ADE环境下搭建了一个ADA4817的测试平台,其中ADA4817为Symbol视图(不含网表),ADE生成的网表为:input.scs
如何仿真???
附
ADA4817.txt 和 input.scs
ADA4817.txt
* The following parameters are accurately modeled;
* FET Input common mode range
* Bandwidth 1050 MHz
* Voltage noise ~ 4nV/rtHz
* Slew Rate ~ 840V/us
* Input Capacitance Cm ~1.3pF and Dm ~0.1pF
* Vos is static and will not vary ~ 1.5 mV
* Distortion is not characterized
* Output Swing swing
* Node assignments
* non-inverting input
* | inverting input
* | | positive supply
* | | | negative supply
* | | | | output
.SUBCKT ADA4817 1 2 99 50 45
* FET INPUT STAGE
*Eos 9 2 poly(1) 100 98 4.2m 1
Vos 9 2 1.5m
Cd 1 2 0.1p
Ccm1 1 0 1.3p
Ccm2 2 0 1.3p
J1 5 1 4 pmod
J2 6 9 4 pmod
Ib1 1 0 2p
Ib2 9 0 2p
Dnil 9 42 DX
Vnil 99 42 3.4
Dpil 1 44 DX
Vpil 99 44 3.4
*R3 50 5 1
*R4 50 6 1
HR3 50 55 VR3 1
VR3 55 5 DC 0
HR4 50 66 VR4 1
VR4 66 6 DC 0
I11 99 4 1m
Ccap 45 2 0.8p
* COMMON-MODE GAIN NETW0RK
Ecm 80 98 POLY(2) 2 98 1 98 0 .5 .5
Ecc 97 0 99 0 1
Ess 52 0 50 0 1
Eref 98 0 POLY(2) 99 0 50 0 0 .5 .5
* GAIN STAGE & POLE AT 130 kHz
G1 13 98 5 6 0.045e3
R7 13 98 rnoise 255e3
*HR7 13 198 VR7 255E3
*VR7 198 98 DC 0
C3 13 98 30p
V1 97 14 1.65
V2 16 52 1.55
D1 13 14 DX
D2 16 13 DX
* POLE AT 1 GHz
G2 98 43 13 98 1
R10 98 43 1
C5 98 43 112p
* POLE AT 1.3 GHz
G3 98 53 43 98 1
R11 98 53 1
C6 98 53 112p
*POLE AT 130 GHz
*G4 98 63 53 98 1
*R12 98 63 rnoise 1
*C7 98 63 0.122p
* BUFFER STAGE
Gbuf 98 81 53 98 1e-2
Rbuf 81 98 100
* OUTPUT STAGE
Vo1 99 90 0
Vo2 51 50 0
R18 25 90 .02
R19 25 51 .02
*D100 45 250 Dx
*D101 250 45 Dx
Vcd 255 45 0
Lout 255 25 0.1p
G6 25 90 99 81 50
G7 51 25 81 50 50
V4 26 25 -0.8355
V5 25 27 -0.8355
D5 81 26 Dx
D6 27 81 DX
Fo1 98 70 vcd 1
D7 70 71 DX
D8 72 70 DX
vi1 71 98 0
Vi2 98 72 0
Erefq 96 0 45 0 1
Iq 99 50 0.0185
Fq1 96 99 POLY(2) Vo1 Vi1 0 1 -1
Fq2 50 96 POLY(2) Vo2 Vi2 0 1 -1
****** Voltage noise stage
rnoise1 39 98 1.8e-3
vnoise1 39 98 0
vnoise2 101 98 0.75
dnoise1 101 39 dn
fnoise1 100 98 vnoise1 1
rnoise2 100 98 1
.model Rnoise RES(T_abs=0)
.model pmod pjf (beta=0.5e-2, T_abs=-10)
.MODEL DX D (T_abs=0)
.model dn d(kf=2e-12,af=1, T_abs=-4)
.ENDS
;$SpiceType=AMBIGUOUS
input.scs
// Generated for: spectre
// Design cell name: tb_ADA4817
// Design view name: schematic
simulator lang=spectre
global 0
include "/home/EDA/IC5141/tools.lnx86/dfII/samples/artist/ahdlLib/quantity.spectre"
// Cell name: ADA4817
// View name: schematic
subckt ADA4817 _1 _2 _45 _50 _99
ends ADA4817
// End of subcircuit definition.
// Cell name: tb_ADA4817
V2 (Signal_IN 0) vsource type=sine ampl=30m freq=10K
V1 (N5V0 0) vsource dc=-5 type=dc
V0 (P5V0 0) vsource dc=5 type=dc
C1 (Signal_IN net25) capacitor c=100.0n
R3 (PreAMP_OUT 0) capacitor c=100.0n
R1 (PreAMP_IN PreAMP_OUT1) capacitor c=1.5p
R6 (0 net25) resistor r=4.7K
R2 (net25 PreAMP_IN) resistor r=330
R0 (PreAMP_IN PreAMP_OUT1) resistor r=3.3K
I5 (PreAMP_OUT1 PreAMP_OUT PreAMP_OUT N5V0 P5V0) ADA4817
I0 (0 PreAMP_IN PreAMP_OUT1 N5V0 P5V0) ADA4817
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
sensfile="../psf/sens.output" checklimitdest=psf
tran tran stop=1m errpreset=moderate write="spectre.ic" \
writefinal="spectre.fc" annotate=status maxiters=5
finalTimeOP info what=oppoint where=rawfile
dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo info what=oppoint where=rawfile
modelParameter info what=models where=rawfile
element info what=inst where=rawfile
outputParameter info what=output where=rawfile
designParamVals info what=parameters where=rawfile
primitives info what=primitives where=rawfile
subckts info what=subckts where=rawfile
saveOptions options save=allpub |
