查看: 2010|回复: 0
[资料] Symbol Scattered Spreading Technique for CDMA
发表于 2012-1-25 13:42:11 | 显示全部楼层 |阅读模式
Abstract:A new spreading scheme is introduced for nullifying the multi-access interference(MAI))for CDMA systems.For a synchronous system,this scheme can keep the orthogonality arnong the codes used to different users in multipath environrnents and,therefore,cancel the MAI cornpletely.In alternation,the  multi-symbols of a user are overlapped and can,however,be calculated.The simulation shows the  effectiveness of this approach for reducing bit error rate(BER)while the system throughputs rernain  unchanged.In addition,the band efficiency is also discussed.
Key Words:CDMA;Spreading scheme
CDMA符号离散扩频技术.pdf
2.88 MB, 下载次数: 16 , 下载积分: 资产 -2 信元, 下载支出 2 信元
GMT+8, 2025-11-25 03:54 , Processed in 0.016923 second(s), 7 queries , Gzip On, Redis On.
