查看: 6397|回复: 3
assura做DRC报错~求解啊。license问题
发表于 2011-12-22 16:14:50 | 显示全部楼层 |阅读模式
Assura (tm) Physical Verification Version av4.1roduction:dfII6.1.3:IC6.1.3.500.15
            Release 4.1_USR1_HF13
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura version av4.1roduction:dfII6.1.3:IC6.1.3.500.15 10/08/2010 03:04 (sfrh50) $
sub-version 4.1_USR1_HF13, integ signature 2010-10-08-0235
run on ppddlove from /home/ppdd/eda/ASSURA/tools.lnx86/assura/bin/32bit/assura on Thu Dec 22 15:36:37 2011
Starting /home/ppdd/eda/ASSURA//tools/assura/bin/aveng /home/ppdd/eda/cds_work/tsmc18/TechFiles/Assura_DRC/assura_drc_run/test.rsf -restart -cdslib /home/ppdd/eda/cds_work/tsmc18/cds.lib
@(#)$CDS: aveng version av4.1roduction:dfII6.1.3:IC6.1.3.500.15 10/08/2010 03:05 (sfrh50) $
run on ppddlove from /home/ppdd/eda/ASSURA/tools.lnx86/assura/bin/32bit/aveng on Thu Dec 22 15:36:37 2011
Summary Report: test.sum
RSF           : /home/ppdd/eda/cds_work/tsmc18/TechFiles/Assura_DRC/assura_drc_run/test.rsf
Library Name  : DCO
CDSLIB Path   : "/home/ppdd/eda/cds_work/tsmc18/cds.lib"
Cell Name     : VCO_test
View Name     : layout
Rules File    : ./TechFiles/Assura_DRC/UM18S3_6M.13b
Options       : -restart -cdslib /home/ppdd/eda/cds_work/tsmc18/cds.lib
Work Directory: /home/ppdd/eda/cds_work/tsmc18/TechFiles/Assura_DRC/assura_drc_run
Operating Mode: Legacy Mode is Off
Checking out license for Assura_DRC 4.10
ERROR (LMF-02008): License call failed for feature Assura_DRC, version 4.100 and quantity 1. The license server search path is defined as 5280@ppddlove:/home/ppdd/eda/ic614/share/license/license.dat. The FLEXnet error message is as follows,
    FLEXnet ERROR(-8, 0, 0): Invalid (inconsistent) license key.
Run 'lic_error LMF-02008' for more information.
*WARNING*
Failed to obtain license for Assura_DRC 4.10
*WARNING* execution terminated
*****  aveng terminated abnormally  *****
*****  aveng fork terminated abnormally  *****
*WARNING* aveng exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
怎么弄啊,求解,有没有遇到一样问题滴~~
 楼主| 发表于 2011-12-23 10:20:13 | 显示全部楼层
木有人回答呃。。。。。。。
发表于 2012-1-30 18:04:50 | 显示全部楼层
It is clear that license key was not right.
发表于 2012-1-30 19:15:58 | 显示全部楼层
It is a little strange.
GMT+8, 2025-12-28 18:55 , Processed in 0.014616 second(s), 4 queries , Gzip On, Redis On.
