查看: 4510|回复: 5
[原创] generateCapTbl core dump problem
发表于 2011-12-22 10:41:41 | 显示全部楼层 |阅读模式
#Start testing solver coyote
#Finished testing solver coyote
**** Start Generating BASIC_CAP_TABLE...
         0%  done at 10:27:23 on 12/22/2011
        10%  done at 10:27:44 on 12/22/2011
        20%  done at 10:28:17 on 12/22/2011
        30%  done at 10:28:48 on 12/22/2011
        40%  done at 10:29:32 on 12/22/2011
        50%  done at 10:30:05 on 12/22/2011
        60%  done at 10:30:46 on 12/22/2011
        70%  done at 10:31:19 on 12/22/2011
        80%  done at 10:32:03 on 12/22/2011
        90%  done at 10:32:41 on 12/22/2011
*** CRASHED *** [signal 11]
Segmentation fault
命令是
generateCapTbl -64 -ict $ict -output  ${ict}.captbl
encounter 8.1 的版本
这个怎么解决
发表于 2011-12-22 13:07:00 | 显示全部楼层
不用-64呢?
发表于 2011-12-22 13:55:52 | 显示全部楼层
我的可以,应该是out of memory之类的错误吧,看起来也有可能是ict文件的问题
 楼主| 发表于 2011-12-22 14:12:30 | 显示全部楼层
用了 -lef lef_header 就行了,  但是-lef不是必要的啊,对吧
现在抽取的很慢
过了1个上午才 80% , 到EXTENDED_CAP_TABLE...
发表于 2011-12-23 00:22:53 | 显示全部楼层
慢工出细活,只要能得到准确的capTable,多花点时间值得
 楼主| 发表于 2011-12-23 09:47:55 | 显示全部楼层
记得我出 40nm的 captable 不需要-lef的,照样出
GMT+8, 2025-12-20 05:26 , Processed in 0.023819 second(s), 6 queries , Gzip On, Redis On.
