查看: 8964|回复: 9
[原创] 急问。VCS怎么加载SDF文件
发表于 2011-12-12 09:15:43 | 显示全部楼层 |阅读模式
加了-sdf max:aaa:file_name.这样的选项。为什么VCS还是报错,说格式错误?
请问正确的命令是什么?
谢谢
 楼主| 发表于 2011-12-12 14:58:06 | 显示全部楼层
多谢回复。现在好了。我在test pattern里面,直接加戴$sdf_annotate();
但这个时候由于sdf的路径是到设计的顶层。而我的gate_sim顶层是到test bench为止。是不是需要人为的修改timing arc的路径?
发表于 2011-12-12 20:10:05 | 显示全部楼层
回复 4# zhq415758192
    学习学习
发表于 2011-12-12 21:48:26 | 显示全部楼层
学习学习
 楼主| 发表于 2011-12-13 09:28:37 | 显示全部楼层
回复 4# zhq415758192
    多谢。有个问题。我的test bench里面例化了两个design.这种情况该怎么标。比如我的design是aaa.
test bench里面有两个,hierachy分别是tb/aaa_0和tb/aaa_1。这种情况怎么弄?谢谢
发表于 2014-3-17 19:43:02 | 显示全部楼层
Separate Annotations
This example shows separate annotations to distinct portions of a design hierarchy. There is
no configuration file specification, so the SDF Annotator uses the defaults.
module top;
cpu m1(i1,i2,i3,o1,o2,o3);
fpu m2 (i4,o1,o3,i2,o4,o5,o6);
dma m3(o1,o4,i5,i6,i2);
// perform annotation
initial
begin
$sdf_annotate("cpu.sdf",m1,,"cpu.log");
$sdf_annotate("fpu.sdf",m2,,"fpu.log");
$sdf_annotate("dma.sdf",m3,,"dma.log");
end
// stimulus and response-checking
endmodule
Annotation with Arrays of Instances
This example shows arrays of instance in a design hierarchy. There is no configuration file
module top;
cpu ar[1](i1,i2,i3,o1,o2,o3);
fpu ar[2](i4,o1,o3,i2,o4,o5,o6);
dma ar[3](o1,o4,i5,i6,i2);
initial
begin
$sdf_annotate("cpu.sdf",ar[1],,"cpu.log");
$sdf_annotate("fpu.sdf",ar[2],,"fpu.log");
$sdf_annotate("dma.sdf",ar[3],,"dma.log");
end
endmodule
发表于 2015-2-11 10:16:28 | 显示全部楼层
GMT+8, 2025-12-17 20:29 , Processed in 0.014761 second(s), 3 queries , Gzip On, Redis On.
