查看: 24397|回复: 137
经典开关电容Ebook--Design for Reliability of Lowvoltage SC Circuits(1999)
发表于 2006-11-17 13:03:45 | 显示全部楼层 |阅读模式
Design for Reliability of Low-voltage,
Switched-capacitor Circuits
Abstract
by
Andrew Masami Abo
Doctor of Philosophy in Engineering
University of California, Berkeley
Professor Paul R. Gray, Chair
Analog, switched-capacitor circuits play a critical role in mixed-signal, analogto-
digital interfaces. They implement a large class of functions, such as sampling,
filtering, and digitization. Furthermore, their implementation makes them
suitable for integration with complex, digital-signal-processing blocks in a compatible,
low-cost technology–particularly CMOS. Even as an increasingly larger
amount of signal processing is done in the digital domain, this critical, analogto-
digital interface is fundamentally necessary. Examples of some integrated applications
include camcorders, wireless LAN transceivers, digital set-top boxes,
and others.
Advances in CMOS technology, however, are driving the operating voltage of
integrated circuits increasingly lower. As device dimensions shrink, the applied
voltages will need to be proportionately scaled in order to guarantee long-term
reliability and manage power density.
The reliability constraints of the technology dictate that the analog circuitry
operate at the same low voltage as the digital circuitry. Furthermore, in achieving
low-voltage operation, the reliability constraints of the technology must not be
violated.
This work examines the voltage limitations of CMOS technology and how analog
circuits can maximize the utility of MOS devices without degrading reliability. An
emphasis is placed on providing circuit solutions that do not require
process enhancements. The specific research contributions of this work include
(1) identifying the MOS device reliability issues that are relevant to switchedcapacitor
circuits, (2) introduction of a new bootstrap technique for operating
MOS transmission gates on a low voltage supply without significantly degrading
device lifetime, (3) development of low-voltage opamp design techniques. With
these design techniques building blocks necessary for switched-capacitor circuits
can be implemented, enabling the creation of sampling, filtering, and data conversion
circuits on low-voltage supplies. As a demonstration, the design and characterization
of an experimental 1.5V, 10-bit, 14.3MS/s, CMOS pipeline analogto-
digital converter is presented.
        Paul R. Gray
[ 本帖最后由 semico_ljj 于 2006-11-17 15:11 编辑 ]
abbr_Reliability of Lowvoltage Switched capacitor Circuits(by Andrew Masami Abo) .pdf
620.34 KB, 下载次数: 646 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-11-17 13:39:39 | 显示全部楼层
Nice one
 楼主| 发表于 2006-11-17 15:12:22 | 显示全部楼层
呵呵,乐者!
发表于 2006-11-17 16:11:22 | 显示全部楼层
kankan
发表于 2006-11-18 07:51:55 | 显示全部楼层
good book
发表于 2006-11-18 07:55:31 | 显示全部楼层
very good bok, thakns
发表于 2006-11-20 11:40:21 | 显示全部楼层
thx a lot
发表于 2006-11-20 11:47:41 | 显示全部楼层
good book
发表于 2006-11-20 14:37:44 | 显示全部楼层
semico_ljj 不愧是大佬,提供资料张贴Abstract.
发表于 2006-11-20 14:49:57 | 显示全部楼层
真不错,刚下了看了看。
145页的东东,有我想要的部分。
GMT+8, 2025-12-28 21:53 , Processed in 0.030347 second(s), 6 queries , Gzip On, Redis On.
