查看: 2725|回复: 1
1个cpu代码,能综合,但控制器时序有问题,哪位高手帮忙看看
发表于 2011-11-27 22:08:07 | 显示全部楼层 |阅读模式
有26条指令,控制器的问题是opcode(指令码)怎么改变时序仿真时都只执行第1条opcode(LDA)的指令功能 ,代码嵌套不多,非常容易看,麻烦哪位有时间,向各位学习了:
module control(clk,rst,empty,opcode,da,in_reg,rd,wr,fetch,alu_ena,ir_ena,da_ena,ld_da_x,ld_ir_ptr,load_ptr,
               load_pc,inc_pc,inc_ptr,dec_ptr,datactl_ena,ld_a,ld_b,halt,stop,dr_o,ld_in,iram_sel,dram_sel,ld_s1,s);
input clk,rst,empty;
input [7:0]opcode,da,in_reg;
output rd,wr,fetch,alu_ena,ir_ena,da_ena,ld_da_x,ld_ir_ptr,load_ptr,load_pc,inc_ptr,dec_ptr,
       inc_pc,datactl_ena,ld_a,ld_b,halt,stop,dr_o,ld_in,iram_sel,dram_sel,ld_s1;
output [2:0]s;
reg rd,wr,fetch,alu_ena,ir_ena,da_ena,ld_da_x,ld_ir_ptr,load_ptr,load_pc,inc_ptr,dec_ptr,inc_pc,
reg [2:0]s;
reg [3:0]state;
parameter LDA=8'b0000_0000,     ADD=8'b0000_0001,     SUB=8'b0000_0010,     OUT=8'b0000_0011,    JMP=8'b0000_0100,     JZ=8'b0000_0101,      JN=8'b0000_0110,
          DATX=8'b0000_0111,    IN=8'b0000_1000,      STR=8'b0000_1001,     SDAN=8'b0000_1010,   STPK=8'b0000_1011,    JK=8'b0000_1100,     XTDA=8'b0000_1101,
          INC=8'b00001_110,     DEC=8'b00001_111,     ZERO=8'b00010_000,    INP=8'b00010_001,    STRP=8'b00010_010,   JEND=8'b00010_011,     LNOT=8'b00010_100,
          LAND=8'b00010_101,    LOR=8'b00010_110,     MULT=8'b00010_111,    DIVI=8'b00011_000,   STP=8'b00011_001;
parameter CLK1=4'b0000,  CLK2=4'b0001,  CLK3=4'b0010,  CLK4=4'b0011,
          CLK5=4'b0100,  CLK6=4'b0101,  CLK7=4'b0110,  CLK8=4'b0111;
always @(posedge clk or posedge rst)
if(rst)  state<=4'b0000;
else
  begin
   {rd,wr,fetch,alu_ena,ir_ena,da_ena,ld_da_x,ld_ir_ptr,load_ptr,load_pc,inc_ptr,dec_ptr,
   inc_pc,datactl_ena,ld_a,ld_b,halt,stop,dr_o,ld_in,iram_sel,dram_sel,ld_s1,s}<=26'b0;
    case(state)
     CLK1:  begin
             fetch<=1;  rd<=1;  iram_sel<=1;  ir_ena<=1;  state<=CLK2;
            end
     CLK2:  begin
             fetch<=1;  inc_pc<=1;  rd<=1;  iram_sel<=1;  ir_ena<=1;  state<=CLK3;
            end
     CLK3:  case(opcode)
                LDA: state<=CLK4;    ADD: state<=CLK4;     SUB: state<=CLK4;     OUT: state<=CLK4;     IN: state<=CLK4;    STR: state<=CLK4;
                SDAN: state<=CLK4;     LAND: state<=CLK4;     LOR: state<=CLK4;     MULT: state<=CLK4;    DIVI: state<=CLK4;   JZ: state<=CLK4;
                JN: state<=CLK4;       JMP: state<=CLK4;      JK: state<=CLK4;      JEND: state<=CLK4;
                INC: begin
                      inc_ptr<=1;  state<=CLK4;
                     end
                DEC: begin
                      dec_ptr<=1;  state<=CLK4;
                     end
                ZERO: begin
                       s<=3'b000;   da_ena<=1;   state<=CLK4;
                      end
                INP:
                 begin
                  ld_ir_ptr<=1;  state<=CLK4;
                 end
                STRP:
                 begin
                  datactl_ena<=1;  wr<=1;  dram_sel<=1;  load_ptr<=1;  state<=CLK4;
                 end
                LNOT:
                 begin
                  ld_a<=1;  state<=CLK4;
                 end
                STPK:
                 begin
                   halt<=1;  state<=CLK4;
                 end
                DATX:
                 begin
                   ld_da_x<=1;  state<=CLK4;
                 end
                XTDA:
                 begin
                   s<=3'b010; da_ena<=1;  state<=CLK4;
                 end
                STP: begin
                      stop<=1;  state<=CLK1;
                    end
               default: state<=CLK4;
             endcase
     CLK4:   begin
              inc_pc<=1;
              case(opcode)
               LDA: state<=CLK5;     ADD: state<=CLK5;    SUB: state<=CLK5;    OUT: state<=CLK5;     IN:  state<=CLK5;     STR: state<=CLK5;
               LAND: state<=CLK5;    LOR: state<=CLK5;    MULT: state<=CLK5;   DIVI: state<=CLK5;    INP: state<=CLK5;     STP: state<=CLK5;
               INC: state<=CLK1;     DEC: state<=CLK1;    STRP: state<=CLK1;   DATX: state<=CLK1;    XTDA: state<=CLK1;    ZERO: state<=CLK1;
               JMP:
                 begin
                   load_pc<=1;   state<=CLK1;
                 end
               JZ:
                 if(da==8'b0)
                  begin
                  end
                 else state<=CLK1;
               JN:
                 if(da<0)
                  begin
                  end
                 else state<=CLK1;
               JEND:
                 if(in_reg==8'h80)
                   begin
                   end
                 else  state<=CLK1;
               SDAN:
                   begin
                     s<=3'b100;   da_ena<=1;   state<=CLK1;
                   end
               LNOT:
                 begin
                    alu_ena<=1;  s<=3'b001;  da_ena<=1;  state<=CLK1;
                 end
               STPK:
                   state<=CLK5;
               JK:
                  if(empty==1)
                    begin
                    end
                  else state<=CLK1;
               default: state<=CLK5;
              endcase
           end
    CLK5:
       begin
        case(opcode)
           LDA:
             begin
               rd<=1;  dram_sel<=1;  s<=3'b011;  da_ena<=1;  state<=CLK1;
             end
           ADD:
             begin
               ld_b<=1;  state<=CLK6;
             end
           SUB:
             begin
             end
           OUT:
             begin
               rd<=1;  dram_sel<=1;  dr_o<=1;  state<=CLK1;
             end
           IN:
             begin
               ld_in<=1;  wr<=1;  dram_sel<=1;  state<=CLK1;
             end
           STR:
             begin
               datactl_ena<=1;  wr<=1;  dram_sel<=1;  state<=CLK1;
             end
           INP:
             begin
               ld_in<=1;  wr<=1;  state<=CLK1;
             end
           LAND:
             begin
             end
           LOR:
             begin
             end
           MULT:
             begin
             end
           DIVI:
             begin
             end
           JMP: state<=CLK1;    JZ: state<=CLK1;    JN: state<=CLK1;    STR: state<=CLK1;    SDAN: state<=CLK1;     INC: state<=CLK1;
           DEC: state<=CLK1;    ZERO: state<=CLK1;  JEND: state<=CLK1;  LNOT: state<=CLK1;   JK: state<=CLK1;       DATX: state<=CLK1;
           XTDA: state<=CLK1;   STP: state<=CLK1;   STPK:  state<=CLK6;
          default: state<=CLK6;
         endcase
      end
    CLK6:
     begin
      case(opcode)
           ADD:
              begin
                 ld_a<=1;  state<=CLK7;
              end
           SUB:
              begin
              end
           LAND:
              begin
              end
           LOR:
              begin
              end
           MULT:
              begin
              end
           DIVI:
              begin
              end
           STPK: state<=CLK7;
           JMP: state<=CLK1;    JZ: state<=CLK1;    JN: state<=CLK1;    STR: state<=CLK1;    SDAN: state<=CLK1;     INC: state<=CLK1;  IN: state<=CLK1;
           XTDA: state<=CLK1;   STP: state<=CLK1;   INP: state<=CLK1;   STR: state<=CLK1;    OUT: state<=CLK1;      LDA: state<=CLK8;
           default: state<=CLK7;
         endcase
      end
    CLK7: begin
          case(opcode)
           ADD:
             begin
             end
           SUB:
             begin
             end
           LAND:
             begin
             end
           LOR:
             begin
             end
           MULT:
             begin
               alu_ena<=1;   s<=3'b001;   da_ena<=1;   state<=CLK8;
             end
           DIVI:
             begin
             end
           STPK: state<=CLK8;
           default: state<=CLK8;
          endcase
        end
    CLK8:
       begin
        case(opcode)
             MULT:
               begin
                 ld_s1<=1;  state<=CLK1;
               end
             DIVI:
               begin
               end
             XTDA: state<=CLK1;   STP: state<=CLK1;   INP: state<=CLK1;   STRP: state<=CLK1;    OUT: state<=CLK1;      LDA: state<=CLK1;
             IN: state<=CLK1;     ADD: state<=CLK1;   SUB: state<=CLK1;   LAND: state<=CLK1;   LOR: state<=CLK1;      STPK: state<=CLK1;
             default: state<=CLK1;
           endcase
        end
   default:   begin
               state<=CLK1;
              end
  endcase
end
endmodule
发表于 2011-12-14 22:54:42 | 显示全部楼层
谁愿意看这个,还不如写
GMT+8, 2025-12-28 09:36 , Processed in 0.014626 second(s), 5 queries , Gzip On, Redis On.
