查看: 2539|回复: 2
[求助] 请帮忙下载以下IEEE论文(timing sign off)
发表于 2011-11-27 08:23:44 | 显示全部楼层 |阅读模式
请帮忙下载以下IEEE论文, 万分感谢!
1)  Pessimism reduction in static timing analysis using interdependent setup
and hold times
Salman, E.; Dasdan, A.; Taraporevala, F.; Kucukcakar, K.; Friedman, E.G.;
Quality Electronic Design, 2006. ISQED '06. 7th International Symposium on
Digital Object Identifier: 10.1109/ISQED.2006.100
Publication Year: 2006 , Page(s): 6 pp. - 164
2)  Effective Corner-Based Techniques for Variation-Aware IC Timing Verification
e Silva, L. G.; Phillips, J.; Silveira, L. M.;
Computer-Aided Design of Integrated Circuits and Systems, IEEE Transactions on
Volume: 29 , Issue: 1
Digital Object Identifier: 10.1109/TCAD.2009.2034343
Publication Year: 2010 , Page(s): 157 - 162
3) A unified Multi-Corner Multi-Mode static timing analysis engine
Jing-Jia Nian; Shih-Heng Tsai; Chung-Yang Huang;
Design Automation Conference (ASP-DAC), 2010 15th Asia and South Pacific
Digital Object Identifier: 10.1109/ASPDAC.2010.5419804
Publication Year: 2010 , Page(s): 669 - 674
4) Post sign-off leakage power optimization
Abrishami, H.; Jinan Lou; Qin, J.; Froessl, J.; Pedram, M.;
Design Automation Conference (DAC), 2011 48th ACM/EDAC/IEEE
Publication Year: 2011 , Page(s): 453 - 458
5) On generating tests to cover diverse worst-case timing corners
Lee, L.; Wu, S.; Wen, C.H.-P.; Wang, L.-C.;
Defect and Fault Tolerance in VLSI Systems, 2005. DFT 2005. 20th IEEE International Symposium on
Digital Object Identifier: 10.1109/DFTVS.2005.50
Publication Year: 2005 , Page(s): 415 - 423
6) Parametric yield-aware sign-off flow in 65/45nm
Byung-Su Kim; Byoung-Hyun Lee; Hung-Bok Choi; Sun-Ik Heo; Jae-Rim Lee; Yong-Cheul Kim; Chul Rim; Kyu-Myung Choi;
SoC Design Conference, 2008. ISOCC '08. International
Volume: 01
Digital Object Identifier: 10.1109/SOCDC.2008.4815576
Publication Year: 2008 , Page(s): I-74 - I-77
7) The impact of variability on design methodology
Visweswariah, C.;
Integrated Circuit Design and Technology, 2005. ICICDT 2005. 2005 International Conference on
Digital Object Identifier: 10.1109/ICICDT.2005.1502619
8) Worst-case timing analysis in UDSM era
Ji Yeon An; Taehoon Kim; Hyung Gyun Yang; Young Hwan Kim;
Electrical Engineering/Electronics Computer Telecommunications and Information Technology (ECTI-CON), 2010 International Conference on
Publication Year: 2010 , Page(s): 376 - 379
9) Improved Timing Windows Overlap Check Using Statistical Timing Analysis
Shrivastava, S.; Parameswaran, H.;
VLSI Design (VLSI Design), 2011 24th International Conference on
Digital Object Identifier: 10.1109/VLSID.2011.21
Publication Year: 2011 , Page(s): 70 - 75
10) Determining the Impact of Within-Die Variation on Circuit Timing
Bashir, M.M.; Milor, L.;
Semiconductor Manufacturing, IEEE Transactions on
Volume: 24 , Issue: 3
Digital Object Identifier: 10.1109/TSM.2011.2152865
Publication Year: 2011 , Page(s): 385 - 391
11) Effective Corner-Based Techniques for Variation-Aware IC Timing Verification
12) Timing signoff uncertainty for UDSM SoC design
Hui Fu;
ASIC, 2003. Proceedings. 5th International Conference on
Volume: 1
Digital Object Identifier: 10.1109/ICASIC.2003.1277503
Publication Year: 2003 , Page(s): 113 - 117 Vol.1
13)  An LLC-OCV Methodology for Statistic Timing Analysis
Hong, J.; Huang, K.; Pong, P.; Pan, J.D.; Kang, J.; Wu, K.C.;
VLSI Design, Automation and Test, 2007. VLSI-DAT 2007. International Symposium
on
Digital Object Identifier: 10.1109/VDAT.2007.373199
Publication Year: 2007 , Page(s): 1 - 4
14) Transition-Time-Relation based capture-safety checking for at-speed scan
test generation
Miyase, K.; Wen, X.; Aso, M.; Furukawa, H.; Yamato, Y.; Kajihara, S.;
Design, Automation & Test in Europe Conference & Exhibition (DATE), 2011
Publication Year: 2011 , Page(s): 1 - 4
15) How does inversed temperature dependence affect timing sign-off
Wu, S.H.; Tetelbaum, A.; Wang, L.-C.;
Integrated Circuit Design and Technology and Tutorial, 2008. ICICDT 2008. IEEE International Conference on
Digital Object Identifier: 10.1109/ICICDT.2008.4567300
Publication Year: 2008 , Page(s): 297 - 300
发表于 2011-11-28 14:01:08 | 显示全部楼层
兄弟,你要的还真多,先给你下两篇,等空了再下。
Effective Corner-Based Techniques for Variation-Aware IC Timing Verification.pdf
177.01 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Pessimism reduction in static timing analysis using interdependent setup.pdf
387.6 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-11-29 10:20:44 | 显示全部楼层
又找了几篇,打了个包,还有的再说啊
桌面.rar
1.61 MB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
GMT+8, 2025-12-27 21:55 , Processed in 0.064367 second(s), 7 queries , Gzip On, Redis On.
