查看: 3310|回复: 2
[求助] ICC setup violation
发表于 2011-11-26 19:26:01 | 显示全部楼层 |阅读模式
Hi, all
plz help me with the following issue, thanks in advance.
when implementing the layout, no setup-violation is issued during setup & floorplan, however, when placement is done, things goes
differently:
and here is the timing report:
Report : timing -path full_clock_expanded -delay max -slack_lesser_than -5.00 -max_paths 1 -transition_time
Design : design
Scenario(s): func_osc_48M
Version: E-2010.12-ICC-SP3-1
Date   : Sat Nov 26 19:11:15 2011
  Startpoint: u_design_core/u_sub1/sub2_r_o_reg
              (rising edge-triggered flip-flop clocked by designter_clk_dec)
  Endpoint: R_O_PAD (output port clocked by designter_clk_dec)
  Scenario: func_osc_48M
  Path Group: designter_clk_dec
  Path Type: max
  Point                                        Trans      Incr       Path      Voltage
  clock designter_clk_dec (rise edge)                    0.00       0.00
  clock network delay (ideal)                             3.00       3.00
  u_design_core/u_sub1/sub2_r_o_reg/CK (SDFPSBNRQ1)
                                                1.00      0.00 #     3.00 r    4.50
  u_design_core/u_sub1/sub2_r_o_reg/Q (SDFPSBNRQ1)
                                               43.74     20.36      23.36 f    4.50
  u_design_core/u_sub1/sub2_r_o (sub1)                   0.00      23.36 f    4.50
  u_design_core/r_o (design_core)                         0.00      23.36 f    4.50
  u_io_pad/r_o_cc (io_pad)                                0.00      23.36 f    4.50
  u_io_pad/r_o/PAD (POT24)                      4.60      9.69 *    33.04 f    4.50
  u_io_pad/r_o_pad (io_pad)                               0.00      33.04 f    4.50
  R_O_PAD (out)                                 4.60      0.00 *    33.04 f    4.50
  data arrival time                                                 33.04
  clock designter_clk_dec (rise edge)                   20.00      20.00
  clock network delay (ideal)                             3.00      23.00
  clock uncertainty                                      -3.10      19.90
  output external delay                                  -8.00      11.90
  data required time                                                11.90
  data arrival time                                                -33.04
  slack (VIOLATED)                                                 -21.14
and from above CLK to Q is more than 20ns, becaused of the unexpected transition time, and now I have two questions:
1.  u_design_core/u_sub1/sub2_r_o_reg/CK (SDFPSBNRQ1)
what's the transition time above, eg, the 43.74 means the transition time of the pin "sub2_r_o_reg/D"(data input port)? why is it so big?
2.why does this happen and how to fix this issue??
regards,
henry
 楼主| 发表于 2011-11-26 22:29:00 | 显示全部楼层
sincerely hoping for your help, thanks
sos~~
发表于 2011-11-26 22:59:45 | 显示全部楼层
too big transition harm this timing,
which process ?
43.7 is the transition of SDFPSBNRQ1/Q  pin,  please report_timing -cap -input_pins  -trans -nets
to see the details
i think there must be huge load after Q pin ,which degrade this flop's timing ,
GMT+8, 2025-12-27 06:39 , Processed in 0.016956 second(s), 5 queries , Gzip On, Redis On.
