查看: 8480|回复: 3
[求助] IP核的例化
发表于 2011-11-22 17:39:32 | 显示全部楼层 |阅读模式
整个过程中有几个警告没有错误,在IP核生成时也有几条警告:WARNING:sim:472 - The chosen IP does not support a Verilog behavioral model,   generating a Verilog structural model instead.WARNING:coreutil - WARNING: Default charset GBK not supported, using ISO-8859-1   insteadWARNING:coreutil - WARNING: Default charset GBK not supported, using ISO-8859-1   instead综合时有警告,仿真输出始终为0。综合时警告如下:WARNING:Xst:2211 - "ipcore_dir/ma.v" line 29: Instantiating black box module <ma>.WARNING:Xst:616 - Invalid property "SYN_BLACK_BOX 1": Did not attach to ar.WARNING:Xst:616 - Invalid property "SYN_NOPRUNE 1": Did not attach to ar.
发表于 2011-11-22 22:36:28 | 显示全部楼层
帮顶一个!
发表于 2013-4-8 00:04:57 | 显示全部楼层
楼主问题解决了吗?我也遇到同样的问题
发表于 2013-4-18 22:38:52 | 显示全部楼层
帮顶,同样的问题
GMT+8, 2025-12-22 20:47 , Processed in 0.018948 second(s), 8 queries , Gzip On, Redis On.
