查看: 19245|回复: 24
[资料] Microwind 3.5 with DSCH 3.5 download link
发表于 2011-10-29 21:49:24 | 显示全部楼层 |阅读模式
Hi
The attachment contains the download link for the microwind
microwind 3.5 downlod weblink.zip (358 Bytes , 下载次数: 404 )
MICROWIND version 3.5 with many new and exciting                                                 features.
Node locked software based licensing to ease        your license management and reduce the security        cost involved in software development.
Supports Windows 2000/XP and new Windows 7        (32/64 bit).
Introduction of 32nm & 45nm technology        design rule file with their application notes.
Added a new screen for        process/Voltage/Temperature Min, Typ, max modes.
Zoom In Navigator added at bottom of the        palette that eases the navigation in the case of        very large designs.
A spectacular command '3D View of the IC'        which enables to draw real-time images of the        layout and navigate in fill-3D on the surface or        inside the IC based on OpenGL and offers        outstanding picture quality.
Metallization macros which ease the addition        of contacts in the layout have been updated to        handle up to 8 layers of metal especially for        45nm technology.
Totally new companion software tutorial        'silicon' to give a user's controlled 3D view of        silicon atoms such as SiO2 and carbon nanotubes.
Improved Global Delay Evaluation at        integrated circuit level.
Enhanced Global Crosstalk evaluation effect        based on analytical approximations of the        coupling amplitude.
Improved and new Help on Design Rules.
Improve drawing speed (specifically pads)        with very large screen resolution.
Improved 3D views for 65, 45 and 32nm        technologies based on Intel/Ibm technologies.
Improved Microwind/Dsch 3.5 manual including        some new features (Ion/Ioff, PVT variations)
DSCH : Added a tool on fault analysis        at the gate level of digital. Faults: Stuck-1,        stuck-at-0. The technique allows injection of        single stuck-at fault at the nodes of the        circuit.
DSCH : Improved interface between        DSCH and Winspice.
..many more improvements in software        function & operation.
发表于 2011-10-30 00:44:25 | 显示全部楼层
菜鸟求QQ,我也想做数字后端
发表于 2011-10-30 02:04:54 | 显示全部楼层
我也想做后端
发表于 2011-11-3 15:48:13 | 显示全部楼层
great thanks
发表于 2011-11-18 08:05:09 | 显示全部楼层
thanks.
发表于 2012-1-2 20:33:04 | 显示全部楼层
thanks.
发表于 2012-10-8 04:35:29 | 显示全部楼层
thanks alot
发表于 2012-10-19 21:56:08 | 显示全部楼层
thanx
发表于 2013-4-30 11:58:31 | 显示全部楼层
thanks.
发表于 2014-3-8 20:38:07 | 显示全部楼层
dsch??
GMT+8, 2025-12-18 14:39 , Processed in 0.023527 second(s), 9 queries , Gzip On, Redis On.
