查看: 2128|回复: 0
[求助] 求一个看门狗电路的VHDL仿真代码
发表于 2011-10-21 09:58:04 | 显示全部楼层 |阅读模式
先谢谢大侠,因为刚开始学习FPGA,对VHDL的仿真不够了解,请您多多指教!下面是看门狗顶层模块代码,求它的VHDL仿真代码,
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity wd is
PORT(
        clk     : IN  STD_LOGIC;
        start   : IN  STD_LOGIC;
        wr      : IN  STD_LOGIC;
        feeddog : IN  STD_LoGIC;
        data    : IN  STD_LOGIC_VECTOR(7 downto 0);
        reset   : OUT STD_LOGIC
end wd;
architecture structural of wd is
COMPONENT wdcmp
PORT(
        clr     : IN   STD_LOGIC;
        clk     : IN   STD_LOGIC;
        wr      : IN   STD_LOGIC;
        data    : IN   STD_LOGIC_VECTOR(7 DOWNTO 0);
        reset   : IN   STD_LOGIC
END COMPONENT;
COMPONENT wdclock
PORT(
   --start   : IN   STD_LOGIC;
        clkin   : IN   STD_LOGIC;
        clr     : IN   STD_LOGIC;
        clk1ms  : IN   STD_LOGIC
   --data    : IN   STD_LOGIC_VECTOR(7 DOWNTO 0);
   --reset   : IN   STD_LOGIC;
END COMPONENT;
COMPONENT wddelay
PORT(
        clk     : IN       STD_LOGIC;
        clr     : IN       STD_LOGIC;
        clrall  : BUFFER   STD_LOGIC
END COMPONENT;
SIGNAL  clk1ms  :  STD_LOGIC;
SIGNAL  clkcmp  :  STD_LOGIC;
SIGNAL  reset_reg : STD_LOGIC;
SIGNAL  clrall  :  STD_LOGIC;
SIGNAL  clr     :  STD_LOGIC;
begin
        U1: wdcmp
        PORT MAP
        start => start,
        clr   => clr,
        clk   => clk,
        wr    => wr,
        data  => data,
        reset => reset_reg
        U2: wdclock
        PORT MAP
        --start => start,
        clkin   => clk,
        clr   => clr,
        clk1ms  => clk1ms
        --wr    => wr,
        --data  => data,
        --reset => reset_reg
        U3: wddelay
        PORT MAP
        clk   => clk1ms,
        clr   => reset_reg,
        clrall => clrall
        clr <= feeddog OR clrall;
        clkcmp <= clk1ms AND NOT (reset_reg);
        reset <= reset_reg;
end structural;
GMT+8, 2025-12-29 00:41 , Processed in 0.020011 second(s), 8 queries , Gzip On, Redis On.
