查看: 2894|回复: 6
[资料] Implementation of CMOS Low-power Integer-N Frequency Synthesizer for SOC Design
发表于 2011-10-11 09:56:23 | 显示全部楼层 |阅读模式
JOURNAL OF COMPUTERS, VOL. 3, NO. 4, APRIL 2008
Abstract—The paper reports the implementation of a frequency synthesizer for system-on-chip (SOC) design. The epi-digital CMOS process is used to provide SOC solution. This work focuses on low-power consumption to achieve longer life-time of batteries. A 2.4GHz frequency synthesizer has been fabricated in 0.18μm epi-digital CMOS technology for ZigBee applications, which consumed 7.95mW from 1.8V supply. The synthesizer has achieved phase-noise of −81.55dBc/Hz and −108.55dBc/Hz at 100kHz and 1MHz offset, respectively. The settling time measured is less than 25μs for an output frequency change of 75MHz from 2.4GHz. The chip core area is 0.75 × 0.65mm2. Index Terms—Frequency  ynthesizers, phase locked loops (PLLs), oscillators, integer-N topology, ZigBee standards, pll.JPG system-on-chip solution, low-power design.
PLL.rar
516.35 KB, 下载次数: 56 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-10-12 09:46:07 | 显示全部楼层
下来看看,谢谢。
发表于 2011-10-12 16:27:24 | 显示全部楼层
板凳!!!谢谢楼主。
发表于 2016-5-17 18:05:39 | 显示全部楼层
THANK YOU
发表于 2016-5-18 22:22:41 | 显示全部楼层
Thanks. Interesting
发表于 2017-8-5 08:57:09 | 显示全部楼层
Thanks
发表于 2019-5-6 21:38:58 | 显示全部楼层
谢谢楼主。
GMT+8, 2025-12-29 00:44 , Processed in 0.022313 second(s), 7 queries , Gzip On, Redis On.
