查看: 3859|回复: 5
[求助] EDI中ecoRoute后提示ILM不能被创建[已解决]
发表于 2011-9-16 15:47:33 | 显示全部楼层 |阅读模式
如题,在run完ecoRoute后提示如下错误:
*ERROR: (ENCILM-281):  There is no netlist associated with the intended ILM specification for cell: dcu_cacheop
**ERROR: (ENCILM-289):  No ILM will be created for cell dcu_cacheop.
**ERROR: (ENCILM-290):  The specification may be from the command 'specifyIlm', GUI, or loading design config file saved from previous 'saveDesign'.
**ERROR: (ENCILM-281):  There is no netlist associated with the intended ILM specification for cell: dcu_cacheop_1
**ERROR: (ENCILM-289):  No ILM will be created for cell dcu_cacheop_1.
可是明明我都指定好了ILM文件,但是还是提示这些错误,哪位大侠能帮帮忙,急需解决,谢谢!
发表于 2011-9-16 15:55:25 | 显示全部楼层
checkDesign 试试, ecoroute完了,
你是  createInterfaceLogic 还是 createILMDataDir 啊
 楼主| 发表于 2011-9-16 16:18:41 | 显示全部楼层
回复 2# icfbicfb
    specifyILM -cell cellname -dir dir
我是用这个命令指定的
 楼主| 发表于 2011-9-16 16:20:32 | 显示全部楼层
回复 2# icfbicfb
我是用这个命令指定的
发表于 2011-9-16 16:36:04 | 显示全部楼层
用上2个命令试试吧
 楼主| 发表于 2011-9-27 16:55:27 | 显示全部楼层
回复 5# icfbicfb
    问题已解决,谢谢
GMT+8, 2025-12-22 15:07 , Processed in 0.055276 second(s), 6 queries , Gzip On, Redis On.
