查看: 4117|回复: 3
[求助] ICC check_library Error
发表于 2011-8-24 23:50:29 | 显示全部楼层 |阅读模式
given below is the report of the following command in IC-Compiler:
set_check_library_options -reset
set_check_library_options -phys_property route
Information: List of routing properties  (LIBCHK-122)
Unit tile : unitTile
              Preferred      Track
   Layer      direction    direction   Offset    Pitch   Remarks
   A1             H            H       0.000     1.800   OK
   A2             V            V       0.900     1.800   OK
   A3                                  0.000     0.000   pitch=0
Error: Mismatched and missing data found. Please refer to LIBCHK-122.  (LIBCHK-101)
however, I checked the tech_file, and verified that the pitch of A3 is defined as 2.6 in the files, and the tf is loaded successfully
why no routing property is reported on A3, and I wanna know that whether ICC generate this info based on the tech_file,
where the preferred_directiona and track_direection...attributes are defined in the tech_file or other files?
regards and thanks in advance.
发表于 2011-8-25 00:57:26 | 显示全部楼层
can i ask is it the HHNEC 0.35/0.5um process ?
for some old process ,  ICC can not support it well since it is the age of Astro ,
if some missing / warning /errors , please go on till the flow can do place&route ,
for icc which is main tool for under 90nm design ,  it may some problem for this large
process ,
please go  on till place&route ,  or change Astro/encounter flow ,
 楼主| 发表于 2011-8-25 08:44:42 | 显示全部楼层
回复 2# icfbicfb
    thank icfbicfb, and your reply does hold true for our design.
发表于 2011-8-26 16:20:31 | 显示全部楼层
0.9um pitch , well , i think is  0.5um or 1um process , is it HHNEC ?
GMT+8, 2025-12-27 17:02 , Processed in 0.019514 second(s), 6 queries , Gzip On, Redis On.
