查看: 6535|回复: 7
[原创] what are the nominal supply voltages(VDD) in different technology nodes ?
发表于 2011-8-10 11:33:38 | 显示全部楼层 |阅读模式
悬赏120资产已解决
what are the nominal supply voltages(VDD) in different technology nodes (e.g 22nm,32nm,45nm,65nm,90nm)in MOS designs?
最佳答案
查看完整内容
for TSMC G process , not LP , LP is higher voltage , like , 1.2v 90nm: 1.0v 65nm : 1.0v 45nm : 0.9v 32nm : 0.85 v TSMC does not have 32nm , deserted it 28nm : 0.85 , same as 32nm , 22nm : may 0.7v , have no such node now ,
发表于 2011-8-10 11:33:39 | 显示全部楼层
90nm:  1.0v
65nm : 1.0v
45nm : 0.9v
 楼主| 发表于 2011-8-10 14:30:12 | 显示全部楼层
回复 2# icfbicfb
    Thank you very much. But now I am using BSIM4 models (from http://ptm.asu.edu/latest.html), is the Vdd should be the same?
发表于 2011-8-10 17:50:15 | 显示全部楼层
please check the detail model card ,
it should be the detail info of SPICE model ,
how you give me the award ?
 楼主| 发表于 2011-8-10 20:31:27 | 显示全部楼层
回复 4# icfbicfb
    hehe,I will choose your answer as the best.   There is a model card of 90nm BSIM4,but I can't find anything about vdd. Can you do me a favour?telling me how to read it. Thank you.
* Beta Version released on 2/22/06
* PTM 90nm NMOS
.model  nmos  nmos  level = 54
+version = 4.0          binunit = 1            paramchk= 1            mobmod  = 0
+capmod  = 2            igcmod  = 1            igbmod  = 1            geomod  = 1
+diomod  = 1            rdsmod  = 0            rbodymod= 1            rgatemod= 1
+permod  = 1            acnqsmod= 0            trnqsmod= 0
+tnom    = 27           toxe    = 2.05e-9      toxp    = 1.4e-9       toxm    = 2.05e-9
+dtox    = 0.65e-9      epsrox  = 3.9          wint    = 5e-009       lint    = 7.5e-009
+ll      = 0            wl      = 0            lln     = 1            wln     = 1
+lw      = 0            ww      = 0            lwn     = 1            wwn     = 1
+lwl     = 0            wwl     = 0            xpart   = 0            toxref  = 2.05e-9
+xl      = -40e-9
+vth0    = 0.397        k1      = 0.4          k2      = 0.01         k3      = 0
+k3b     = 0            w0      = 2.5e-006     dvt0    = 1            dvt1    = 2
+dvt2    = -0.032       dvt0w   = 0            dvt1w   = 0            dvt2w   = 0
+dsub    = 0.1          minv    = 0.05         voffl   = 0            dvtp0   = 1.2e-009
+dvtp1   = 0.1          lpe0    = 0            lpeb    = 0            xj      = 2.8e-008
+ngate   = 2e+020       ndep    = 1.94e+018    nsd     = 2e+020       phin    = 0
+cdsc    = 0.0002       cdscb   = 0            cdscd   = 0            cit     = 0
+voff    = -0.13        nfactor = 1.7          eta0    = 0.0074       etab    = 0
+vfb     = -0.55        u0      = 0.0547       ua      = 6e-010       ub      = 1.2e-018
+uc      = -3e-011      vsat    = 113760       a0      = 1.0          ags     = 1e-020
+a1      = 0            a2      = 1            b0      = -1e-020      b1      = 0
+keta    = 0.04         dwg     = 0            dwb     = 0            pclm    = 0.06
+pdiblc1 = 0.001        pdiblc2 = 0.001        pdiblcb = -0.005       drout   = 0.5
+pvag    = 1e-020       delta   = 0.01         pscbe1  = 8.14e+008    pscbe2  = 1e-007
+fprout  = 0.2          pdits   = 0.08         pditsd  = 0.23         pditsl  = 2.3e+006
+rsh     = 5            rdsw    = 180          rsw     = 90           rdw     = 90
+rdswmin = 0            rdwmin  = 0            rswmin  = 0            prwg    = 0
+prwb    = 6.8e-011     wr      = 1            alpha0  = 0.074        alpha1  = 0.005
+beta0   = 30           agidl   = 0.0002       bgidl   = 2.1e+009     cgidl   = 0.0002
+egidl   = 0.8
+aigbacc = 0.012        bigbacc = 0.0028       cigbacc = 0.002
+nigbacc = 1            aigbinv = 0.014        bigbinv = 0.004        cigbinv = 0.004
+eigbinv = 1.1          nigbinv = 3            aigc    = 0.012        bigc    = 0.0028
+cigc    = 0.002        aigsd   = 0.012        bigsd   = 0.0028       cigsd   = 0.002
+nigc    = 1            poxedge = 1            pigcd   = 1            ntox    = 1
+xrcrg1  = 12           xrcrg2  = 5
+cgso    = 1.9e-010     cgdo    = 1.9e-010     cgbo    = 2.56e-011    cgdl    = 2.653e-10
+cgsl    = 2.653e-10    ckappas = 0.03         ckappad = 0.03         acde    = 1
+moin    = 15           noff    = 0.9          voffcv  = 0.02
+kt1     = -0.11        kt1l    = 0            kt2     = 0.022        ute     = -1.5
+ua1     = 4.31e-009    ub1     = 7.61e-018    uc1     = -5.6e-011    prt     = 0
+at      = 33000
+fnoimod = 1            tnoimod = 0
+jss     = 0.0001       jsws    = 1e-011       jswgs   = 1e-010       njs     = 1
+ijthsfwd= 0.01         ijthsrev= 0.001        bvs     = 10           xjbvs   = 1
+jsd     = 0.0001       jswd    = 1e-011       jswgd   = 1e-010       njd     = 1
+ijthdfwd= 0.01         ijthdrev= 0.001        bvd     = 10           xjbvd   = 1
+pbs     = 1            cjs     = 0.0005       mjs     = 0.5          pbsws   = 1
+cjsws   = 5e-010       mjsws   = 0.33         pbswgs  = 1            cjswgs  = 3e-010
+mjswgs  = 0.33         pbd     = 1            cjd     = 0.0005       mjd     = 0.5
+pbswd   = 1            cjswd   = 5e-010       mjswd   = 0.33         pbswgd  = 1
+cjswgd  = 5e-010       mjswgd  = 0.33         tpb     = 0.005        tcj     = 0.001
+tpbsw   = 0.005        tcjsw   = 0.001        tpbswg  = 0.005        tcjswg  = 0.001
+xtis    = 3            xtid    = 3
+dmcg    = 0e-006       dmci    = 0e-006       dmdg    = 0e-006       dmcgt   = 0e-007
+dwj     = 0.0e-008     xgw     = 0e-007       xgl     = 0e-008
+rshg    = 0.4          gbmin   = 1e-010       rbpb    = 5            rbpd    = 15
+rbps    = 15           rbdb    = 15           rbsb    = 15           ngcon   = 1
* PTM 90nm PMOS
.model  pmos  pmos  level = 54
+tnom    = 27           toxe    = 2.15e-009    toxp    = 1.4e-009     toxm    = 2.15e-009
+dtox    = 0.75e-9      epsrox  = 3.9          wint    = 5e-009       lint    = 7.5e-009
+lwl     = 0            wwl     = 0            xpart   = 0            toxref  = 2.15e-009
+xl      = -40e-9
+vth0    = -0.339       k1      = 0.4          k2      = -0.01        k3      = 0
+dsub    = 0.1          minv    = 0.05         voffl   = 0            dvtp0   = 1e-009
+dvtp1   = 0.05         lpe0    = 0            lpeb    = 0            xj      = 2.8e-008
+ngate   = 2e+020       ndep    = 1.43e+018    nsd     = 2e+020       phin    = 0
+cdsc    = 0.000258     cdscb   = 0            cdscd   = 6.1e-008     cit     = 0
+voff    = -0.126       nfactor = 1.7          eta0    = 0.0074       etab    = 0
+vfb     = 0.55         u0      = 0.00711      ua      = 2.0e-009     ub      = 0.5e-018
+uc      = -3e-011      vsat    = 70000        a0      = 1.0          ags     = 1e-020
+a1      = 0            a2      = 1            b0      = 0            b1      = 0
+keta    = -0.047       dwg     = 0            dwb     = 0            pclm    = 0.12
+pdiblc1 = 0.001        pdiblc2 = 0.001        pdiblcb = 3.4e-008     drout   = 0.56
+pvag    = 1e-020       delta   = 0.01         pscbe1  = 8.14e+008    pscbe2  = 9.58e-007
+rsh     = 5            rdsw    = 200          rsw     = 100          rdw     = 100
+rdswmin = 0            rdwmin  = 0            rswmin  = 0            prwg    = 3.22e-008
+egidl   = 0.8
+eigbinv = 1.1          nigbinv = 3            aigc    = 0.69         bigc    = 0.0012
+cigc    = 0.0008       aigsd   = 0.0087       bigsd   = 0.0012       cigsd   = 0.0008
+cgso    = 1.8e-010     cgdo    = 1.8e-010     cgbo    = 2.56e-011    cgdl    = 2.653e-10
+at      = 33000
+xtis    = 3            xtid    = 3
发表于 2011-8-11 15:41:16 | 显示全部楼层
sorry, i seldom use analog spice simulator , since i am digital backend place&route designer ,
the norminal voltage is from design rule , or .lib file ,
i dont know how spice model correlate with it ,  please ask other analog circuit designer ,
thanks for your money as well!!
发表于 2011-8-11 17:28:47 | 显示全部楼层
i have asked 2 of my friends , who do analog design ,
the operting voltage is manual setting , does not from spice model card ,
like  .OP XXX voltage
 楼主| 发表于 2011-8-11 19:56:35 | 显示全部楼层
回复 7# icfbicfb
    Thank you anyway.
GMT+8, 2025-9-17 03:25 , Processed in 0.020149 second(s), 6 queries , Gzip On, Redis On.
