楼主: eda_dude
[原创] Cadence MMSIM10.1 32 bit patch
发表于 2012-3-15 22:45:01 | 显示全部楼层
thanks very much
发表于 2012-3-19 10:33:53 | 显示全部楼层
可惡耶
裡面有少檔案阿
发表于 2012-3-23 00:13:28 | 显示全部楼层
IC615能用么?
发表于 2012-3-25 01:59:09 | 显示全部楼层
thanks alot ~!~!1`
发表于 2012-3-25 01:59:46 | 显示全部楼层
thanks alo123lkj3214lkj so cute!~!
发表于 2012-3-26 20:48:13 | 显示全部楼层
kkkkkkkkkkkkkkkkkdd
发表于 2012-4-30 22:14:46 | 显示全部楼层
没有sfk文档,用以前的可以吗
发表于 2012-5-17 19:18:25 | 显示全部楼层
Thanks a lot!!!
Can anybody tell how use patch. I should to copy this file in install dir, or run in terminall?
发表于 2012-5-17 22:16:13 | 显示全部楼层
回复 52# nikki1986
    need to execute at install directory (at the top top level of installation).  If you redirect output to a file it is possible than to look what is fixed and find errors if any. Otherwise it is not easy to follow what is going on and once it is done there is no record of what happened. Good luck.
发表于 2012-5-26 12:33:20 | 显示全部楼层
請問這是啥tools 呢??
GMT+8, 2025-12-24 11:23 , Processed in 0.062433 second(s), 5 queries , Gzip On, Redis On.
