楼主: xlstoner
CMOS带隙基准电压源
发表于 2007-3-5 22:56:48 | 显示全部楼层
Cool stuff
发表于 2007-3-5 23:02:10 | 显示全部楼层
这个好么/?
发表于 2007-3-5 23:13:16 | 显示全部楼层
thanks
发表于 2007-3-11 02:01:36 | 显示全部楼层
下来,看看!
发表于 2007-3-12 09:51:58 | 显示全部楼层
A 1.1 V Current-Mode and Piecewise-Linear Curvature Corrected Bandgap Reference.pdf
A CMOS Bandgap Reference Circuit with Sub-1-V Operation.pdf
A CMOS Bandgap Reference without Resistors.pdf
A CMOS PRECISION VOLTAGE REFERENCE IC.pdf
A Curvature Compensation Technique for Bandgap Voltage References Using Adaptive Reference Temperature.pdf
A Sub-1-V 15-ppm C CMOS Bandgap Voltage Reference.pdf
An Improved Tail Current Source for Low Voltage Applications.pdf
bandgap circuit.rar
Bandgap Voltage and Current Reference Designer.pdf
Bandgap Voltage and Current Reference Designer1.pdf
bandgap-1.pdf
bandgap-2.pdf
bandgap-fikret.pdf
bandgap.pdf
bandgap0.pdf
bandgap2.pdf
Bandgap_papers.pdf
Bandgap_reference.pdf
bandgap_report.pdf
Basic and advanced current references.pdf
Beta Multiplier Referenced Self-Biasing.pdf
BiasCircuits.pdf
BiasingCircuits.ppt
Curvature Compensated BiCMOS Bandgap with 1 V Supply Voltage.pdf
CURVATURE COMPENSATED BICMOS BANDGAP WITH 1V SUPPLY VOLTAGE.pdf
DESIGN AND ANALYSIS OF THE BANDGAP REFERENCE.pdf
Design methods of low-voltage curvature-corrected bipolar bandgap references based on the sum of base-emitter voltages.pdf
DESIGN OF A 1-V LOW POWER CMOS BANDGAP REFERENCE BASED ON RESISTIVE SUBDIVISION.pdf
Low Noise Sub-Bandgap Voltage Reference.pdf
low volt low power cmos bandgap ref.pdf
Low Voltage, Low Power CMOS Bandgap References.pdf
Low-Power CMOS On-Chip Voltage Reference Using MOS PTAT An EP Approach.pdf
Low-voltage Voltage Reference Using Current Mode Approach.pdf
pp59-68.pdf
Statistical Analysis and Optimization of a Bandgap Reference for VLSI Applications.pdf
一种10_ppm~oC低压CMOS带隙电压基准源设计.PDF
一种低压CMOS带隙电压基准源.pdf
一种低电源电压带隙基准的设计.pdf
一种基于斩波调制的低压高精度CMOS带隙基准源.pdf
一种新型低压高精度CMOS电流源.PDF
一种高性能CMOS带隙电压基准源设计.PDF
一种高精度的CMOS带隙基准电压源.pdf
低压CMOS带隙电压基准源设计.PDF
低电压基准电压源.pdf
基于MOSFET失配分析的低压高精度CMOS带隙基准源.PDF
基于衬底驱动技术的亚1V与温度成正比基准源.PDF
多方位提高电源性能:CMOS带隙基准电压电路的实用设计.pdf
指数型补偿带隙基准源.pdf
用于流水线ADC中的带隙基准的研究.pdf
发表于 2007-3-12 11:51:25 | 显示全部楼层
原帖由 xmysz 于 2006-11-13 02:59 发表
天哪,现在才知道。php文件直接下载,再改名就成了,浪费了我无数分数啊,希望论坛做成edaboard那样,下载过再次下载就不要钱了的
怎么个意思?下载不要钱了?
发表于 2007-3-16 01:04:16 | 显示全部楼层
必须顶了、、、
发表于 2007-3-16 02:20:28 | 显示全部楼层
can not open it. Cheater
发表于 2007-3-16 02:22:36 | 显示全部楼层
How to open it?
发表于 2007-4-9 16:28:49 | 显示全部楼层
下载,收藏,谢谢!
基准,运放,呵呵,永远的焦点阿!
GMT+8, 2025-12-30 16:00 , Processed in 0.019047 second(s), 4 queries , Gzip On, Redis On.
