查看: 6325|回复: 14
vcs mx 2010 .06 problem
发表于 2011-7-22 17:32:38 | 显示全部楼层 |阅读模式
I downloaded vcs mx 2010.06 that exits in this site. I installed and I am sure that I am using the right license but I think I did not write the right command in terminal. what is the cshrc for this software I used this:
export PATH="/home/vahid/synopsys/VCS2010/bin:"$PATH
export PATH="/home/vahid/synopsys/SCL/linux/bin:"$PATH
alias lmli2="lmgrd -c /home/vahid/synopsys/lic/license.dat -l ~/syn_lic.log"
export VCS_HOME="/home/vahid/synopsys/VCS2010"
export SYNOPSYS="/home/vahid/synopsys/VCS2010"
export VMC_HOME="/home/vahid/synopsys/VCS2010"
export VCSI_HOME="/home/vahid/synopsys/VCS2010"
export SNPSLMD_LICENSE_FILE=27000@ubuntu
alias vcs="vcs_shell"
alias dve="dve_shell"
/home/vahid/synopsys/SCL/linux/bin/lmgrd -c /home/vahid/synopsys/lic/license.dat
vcs -gui
dve
but when I using dve or vcs in terminal I got this message
vcs_shell: command not found
could anyone post the command for using yhis software
发表于 2011-7-22 17:47:26 | 显示全部楼层
Please first check your DISPLAY
 楼主| 发表于 2011-7-23 00:18:40 | 显示全部楼层
thanks, but it did not solve my problem, other opinion?
发表于 2011-7-23 00:55:03 | 显示全部楼层
check your PATH or the exacutable file name
 楼主| 发表于 2011-7-23 06:31:56 | 显示全部楼层
thanks guys. but I could solve this problem with this procedure:
export VCS_HOME=/home/vahid/synopsys/VCS2010
export PATH="/home/vahid/synopsys/VCS2010/gui/dve/bin:"$PATH
Then I dragged the dve file from "/home/vahid/synopsys/VCS2010/gui/dve/bin" to terminal window and dve was started
发表于 2011-7-28 12:56:26 | 显示全部楼层
let me tell you something. your script is too complex,there is no need to setup such a complex script. you only need set the path for VCS, when you have compiled your design, the software can find dve automatically . my .bashrc is like following
    export SNPS_HOME=/tools/synopsys
    export VCS_HOME=$SNPS_HOME/vcs_vD-2010.06
    export $PATH=$PATHVCS_HOME/bin
    export SNPSLMD_LICENSE_FILE=/tools/synopsys/license.dat
发表于 2011-10-15 07:58:16 | 显示全部楼层
learning..............
发表于 2011-11-25 17:00:41 | 显示全部楼层
Could you tell me how to install the VCS 2010 please? Now I can't install the "common file", I also download the programe at this website,It has no "scl" file .
发表于 2013-6-14 15:44:01 | 显示全部楼层
回复 1# ald_syn_cad
  解决了我的大问题,找了n久,原来问题在这里,谢谢了
发表于 2013-12-8 21:19:36 | 显示全部楼层
回复 1# ald_syn_cad
   did you solve the problem or not.
If yes please guide me , i am also facing the same problem.
GMT+8, 2025-10-8 02:50 , Processed in 0.018920 second(s), 5 queries , Gzip On, Redis On.
