查看: 4525|回复: 6
[求助] ADS仿真碰到一个问题!急!求教!~
发表于 2011-7-5 16:46:12 | 显示全部楼层 |阅读模式
下图是我设计的差分放大器电路原理图,在ADS里进行交流仿真。这是我用ADS仿真的结果,中间TL+,TL-这2根线的电压差值最高时才1.9V,可我的信号源是1V的呀,请问这是怎么回事呢?正常吗?谢谢!!!
发表于 2011-7-5 18:14:40 | 显示全部楼层
Have you ever designed some circuits before? Do you know how to analyze gain of your circuit?
check current in current source and you can already estimate gm and then the gain
 楼主| 发表于 2011-7-6 10:07:23 | 显示全部楼层
回复 2# hezudao
    我还是不太明白 那就是说要先求出gm然后算出增益?
   但我现在是用ADS工具进行仿真 直接看结果应该就是了吧?
我这个是单端输入差分输出的差分放大器,[ (TL+) -(TL-) ] /RFin 不就是差模增益吗?
请指教!
发表于 2011-7-6 14:56:58 | 显示全部楼层
仿增益哪有用这么大信号仿的啊
发表于 2011-7-6 15:00:55 | 显示全部楼层
回复 4# ckkckk
    It's ac simulation, so whatever you use for amplitude, it does not matter. you should get same results
发表于 2011-7-6 15:07:48 | 显示全部楼层
回复 3# wkjatzju
    I mean if you want to understand why gain is low, you should at least know how to analyze your circuit. You probably already have a number in mind before you run simulation. To drive 100 ohm, you might need at least more than 1.25mA to get positive gain(in dB). Check your current. Is there any CMOS circuit design course taught in ZJU now?
 楼主| 发表于 2011-7-6 16:02:20 | 显示全部楼层
回复 6# hezudao
    QQ  125538673 可否加我?
GMT+8, 2025-12-25 15:22 , Processed in 0.023859 second(s), 7 queries , Gzip On, Redis On.
