查看: 4500|回复: 9
[招聘] Fairchild Semiconductor招聘(内部推荐)
发表于 2011-7-4 17:05:59 | 显示全部楼层 |阅读模式
R&D
Job Titile                                     Location
Layout Engineer                           Beijing
Sr.Layout Engineer                       Beijing
Sr.Design Engineer_ Analog          Beijing
Design Enablement Engineer         Beijing
Mixed-signal Designer                   Beijing/Shanghai
Sales&Marketing
Job Titile                                                              Location
Distribution Sales Manager                                     Shanghai
Finance Intern                                                       Shanghai
FAE        Shanghai
Sr.FSE        Shanghai
Account Clerk                                                         Shenzhen
FAE        Shenzhen
Senior Field Application Engineer for Emerson          Shenzhen
Sales Manager                                                        Beijing
FAE        Hangzhou
有意向的可以把简历发给我xqyu2008@gmail.com
 楼主| 发表于 2011-7-4 17:07:27 | 显示全部楼层
Job Title: Layout engineer
    Vacancy:  2(1 senior 1 inter)
Duties
•        Layout floor planning, physical layout, routing, and verification including DRC, LVS, and LPE Digital Synthesis, Place & Route, and verification
•        Layout techniques to improve circuit performance
•        Work with designer to define optimal layout solutions, based on design objectives
Requirements
•        Experience in analog IC layout skills, like bandgap voltage reference, devices matching and ESD/Latchup knowledge
•        Experience in high current, high voltage circuit layout, high accuracy Opamp is a plus
•        Experience in Cadence IC Layout tool set
•        With chip Layout experience is a plus
•        Team-based, cross-functional organizational structure experience preferred
•        BS degree or equivalent experience
•        Strong communications skills; written, verbal, presentation and listening;
•        Good interpersonal skills to work in a team environment;
•        Good command of written and spoken English required;
•        Excellent interpersonal, written communication and presentation skills
Job Title: Sr. Design engineer
Vacancy:  1
Duties
•        Analog IC circuit design; simulation; and verification
•        Work on the design of analog products and blocks like high current or high capacitive load output drivers, op amps, voltage references, oscillators, error amplifiers, and voltage regulators
•        Work with product definition; characterization, and test engineers in the full product development flow; Work with application & test engineers to define optimal design and characterization solutions, based on design objectives
•        Layout floor planning, including DRC, LVS, and LPE
Requirements
•        Knowledge in analog CMOS/BiCMOS IC design
•        Knowledge in analog IC layout;Experience in Cadence IC Design tool set, simulation, verification
•        With project design experience is a plus
•        MSEE degree or equivalent experience
Job Title: Design Automation Engineer
Vacancy:  1
Duties
•        Responsible for generating reuse methodology/toolsets to aid in esign/Layout cycletime reduction as well as Design Iteration reduction.
•        Understand and support an automated CAD environment for the usage of both design and layout community.
•        Generate automated valid device layouts through coding to reduce layout cycle time.
•        Able to use the CAD tools to examine technology and design rule suitability for manufacturing and to diagnose problems.
•        Support the design community with any CAD/software related issues.
•        Support the design community with any Digital/Standard Cell design related issues.
•        Reporting requirements:Weekly and period project status reports.
Documentation of methodology and development flows.
Requirements
•        M.S., PhD, Electrical Engineering, Microelectronics, or B.S. with experience
Experience in schematic capture though SPICE simulation flow.
•        Experience in schematic capture to layout generation flow.
•        Strong programming skill is required, minimum of Perl and shell scripting.
•        Ability to translate a raw SPICE netlist to schematic.
•        Familiarity with semiconductor devices, including MOS, Bipolar, Diode, resistors, capacitors, etc.
•        Knowledge of the operation of these devices in digital or analog applications.
•        Familiarity with ESD and latch-up simulation a plus.
•        Strong knowledge of problem analysis and diagnostic techniques.
•        Basic understanding of statistics and design of experiments a plus.
•        Experience in behavioral and synthesis flows a plus.
•        Familiarity with the Linux operating environment.
•        Familiarity with the Windows operating environment.
•        Good English communication capabilities.
•        MS degree or equivalent experience
•        Results oriented.
•        Highly motivated in the pursuit of solutions to challenging technical problems.
•        Strong communications skills (written, verbal, presentation and listening).
•        Strong interpersonal skills.
•        Willingness to work flexible hours, as needed, to allow communications with Design sites.
•        Able to work independently and be self guided.
•        Effectively analyzes situations; weighs alternatives – makes a decision – then executes.
•        Willingness to continue learning new Design Automation techniques by independently reading and studying technical publications.
•        Able to successfully manage multiple projects at a time.
Job Title: Mixed-signal designer(Interview by US in July)
Vacancy:  1
Summary of job description:
•        Design and validate cost effective, analog/mixed-signal IC solutions for
sensor applications
Education and experience requirement
•        PhD in EE, MSEE and 4+ years of and/or mixed-signal IC industry design
•        experience; or BS and 6+  years of analog and/or mixed-signal IC industry
•        design experience
•        Experience in designing sensors interface IC strongly preferred
•        Hands-on CMOS product design experience in two or more of the following
•        areas
•        Receiver front end, including analog front-end, demodulation, channel
•        selection etc.
•        High-precision ADC, including sigma-delta, pipeline etc
•        High-precision DAC
•        Fully-differential continuous and discrete-time (e.g. switched capacitor)
•        amplifier/filter design
•        High-precision oscillator/PLL/DLL
•        Low noise voltage reference
•        On-chip high-voltage charge pump
•        Experience in system level definition, modeling and verification a plus
•        Hands-on experience supervising layout and post-layout verification
•        Proficiency in tools
•        Cadence design environment
•        Verilog/VerilogA/Matlab or other tools for system level modeling and
•        verification  a plus
 楼主| 发表于 2011-7-4 17:08:55 | 显示全部楼层
Job Title: Distribution Sales Manager
Vacancy:  1
Hiring Manager: Sam Yiu
Duties
•        To develop channel strategy to maximize the revenue growth
•        To work closely with distributors on assets management through detailed & inventory/resales analysis to identify issues and opportunities tactically
•        To develop programs to improve assets position and the resales activities to ultimately grow the business with distributors profitably
•        To provide the updated forecast on billings and resales activities and drive to meet and exceed the annual goal plan.
•        To enforce & maintain data accuracy on the reported distribution inventory/resales
•        To be able to provide data analysis reports with corrective actions to solve ad hoc   assets issues
Requirements
•        Minimum 7 years of experience in managerial grade preferably in sales and marketing in the China market.  Experiences in distribution operations is an asset
•        University graduate in Electronics Engineering or related disciplines
•        Strong business acumen with excellent communications skills
•        Good command of written and spoken English and Mandarin
Job Title: Sr. Field Application Engineer
Vacancy:  4
Hiring Manager :Robin Zhang
Duties
•        Promote new products to E.China motion control (air-conditioner, washing machine, industrial motion, etc.) customers.
•        Provide field application support to customers.
•        Market survey for motion related new applications, and penetrate the new market with Fairchild solutions.
•        Provide product and system training to distributor FAE and sales.
•        Submit NPR to PL for new device requirement.
Requirements
•        Over 5 years motion control(inverter air-con, refrigerator, e-bike, sewing
•        machine, pump, general inverter, etc.) hard ware design or FAE experience.
•        Practical experience for motion control and high power application design.
•        Bachelor degree for power electronics and motor drive. Master is preferred.
•        Be able to communicate in English, written and oral.
Job Title: Account Clerk
Vacancy:  1
Hiring Manager: Pauline Ng
To provide financial, clerical and administrative services to ensure efficient, timely and accurate payment of accounts under his or her control.
Duties
•         Responsibility for AR and Billing
•         Maintain up-to-date billing system
•        Follow up, collection and allocation of payments
•        Carry out billing, collection and reporting activities according to specific deadlines
•        Reconciliation of accounts
•        Monitoring customer account details for non payments, delayed payments and other irregularities
•        Maintain accounts receivable customer files
•        Follow established procedures for processing receipts, cash etc
•        Investigate and resolve customer queries
•        Process adjustments
•        Organizing a recovery system and initiate collection efforts
•        Communicating with customers via phone, email, mail or personally
•        knowledge of accounts receivable
•        knowledge of office administration and procedures
•        knowledge of general bookkeeping procedures
•        proficient in relevant computer applications
•        3 years accounts receivable and general accounting experience
•        University graduated in Finance/ Account
Requirements
•        attention to detail and accuracy
•        interpersonal skills
•        good communication skills
•        organizational skills
•        information management
•        problem-solving skills
•        decision-making skills
•        stress tolerance
•        tenacious
•        negotiation skills
•        conflict management skills
Job Title: Sales Manager
Vacancy:  1
Hiring Manager: Wang Jian
Duties
•        To develop North China region business, including Beijing, Tianjin, Dalian, Xi'an and Qingdao
•        To develop sales team's capability by coaching, especially to improve sales team's new change in process and account management
•        To improve and maintain key customers' relationship with Fairchild
•        To manage sales channel in related region, to maximize distributors' resource and productivities
Requirements
•        10 years+ experience in semiconductor industry.
•        2+ years experience in leading sales people in an office
•        Experience in systematic sales process and account management Experience in power management, power components are preferred
•        Electric and Electronics major, bachelor and above
•        Good writing and oral English
•        Good communication skill and coordination capability
Job Title: Sr.FSE
Vacancy:  1
Duties
•         To improve and maintain relationship with key customers.
•         To achieve sales goal by securing design-win and Fairchild's share in key accounts
•         To develop new business opportunities in new market segment
•         To push distributors for new opportunities, better support to key customers
Requirements
•         5+ years experience in semiconductor industry as a sales person
•         Experience in handling key accounts and develop account relationship
•         Experience in developing new opportunities by design-in.
•         Experience in semiconductor suppliers is preferred
•         Experience in power supply, solar, lighting and other power related application is preferred.
•          Electric and Electronics related major, bachelor or above
•        Good written and oral English
•         Self-encouragement, willing to win
Job Title: Senior Field Application Engineer for Emerson
Vacancy:  1
Duties:
•        Responsible for new product promotions
•        Provide application support to customers
•        Work closely with sales personnel to get new product design-win
•        Collect market information, propose new product request to production line
Requirements:
•        Over 5 years experience in switch mode power supply design
•        BSc Degree in Electronic Engineering or equivalent. Master is preferred
•        Semiconductor FAE experience will be an added advantage
•        Mature, self-motivated and able to work independently
•        Fluent in English, Cantonese and Mandarin.
发表于 2011-7-4 18:17:00 | 显示全部楼层
Sr.Layout Engineer    待遇怎样?
 楼主| 发表于 2011-7-5 09:13:55 | 显示全部楼层
待遇直接跟manager谈
发表于 2011-7-5 13:44:38 | 显示全部楼层
要求好高。。
发表于 2011-7-5 20:49:39 | 显示全部楼层
哇~~好公司呀。
发表于 2011-7-7 20:41:54 | 显示全部楼层
    应届硕士生可以吗?谢谢。
发表于 2011-8-17 15:45:50 | 显示全部楼层
有邮箱吗?我有兴趣试一试。
我的QQ:601415174
发表于 2016-6-28 21:43:25 | 显示全部楼层
good material
GMT+8, 2025-12-26 15:59 , Processed in 0.022832 second(s), 7 queries , Gzip On, Redis On.
