查看: 7015|回复: 33
[IEEE Paper]Solutions for CMOS Current Amplifier with High-Drive Output Stages
发表于 2006-11-1 20:42:10 | 显示全部楼层 |阅读模式
Title-Solutions for CMOS Current Amplifier with High-Drive Output Stages
Authors-Giuseppe Palmisano, Associate Member, IEEE, Gaetano Palumbo, Senior Member, IEEE, and Salvatore Pennisi
Abstract—Design guidelines for CMOS current amplifiers with a high-drive capability are discussed in detail, paying special attention to the implementation of output stages with improved linearity performance. As a design example, two different current amplifiers were realized in a 1.2- m process and experimentally tested. Both circuits used a 5-V power supply and dissipated 5.5 and 4 mW, respectively. The open-loop gain was found to be 90 and 100 dB and the gain-bandwidth product was 8 and 10 MHz. The two amplifiers provide bipolar output currents as high as 15 and 7 mA, with a maximum total harmonic distortion of around 54 dB, using a quiescent current in the output branches of only 200 A.
Index Terms—CMOS analog integrated circuits, current mode, integrated circuit design, operational amplifiers, power amplifiers.
Solutions for CMOS Current Amplifier with High-Drive Output Stages.pdf
206.97 KB, 下载次数: 148 , 下载积分: 资产 -2 信元, 下载支出 2 信元
IEEE Paper
发表于 2006-11-2 08:09:02 | 显示全部楼层
下了,正看中!
发表于 2007-6-5 15:10:49 | 显示全部楼层
正在找关于电流amp的资料,谢lz,lz是好人
发表于 2007-7-14 16:53:36 | 显示全部楼层
不错,挺好
发表于 2007-9-23 18:30:57 | 显示全部楼层
thank you
发表于 2007-9-26 23:48:36 | 显示全部楼层
haohaohao
发表于 2007-9-26 23:49:49 | 显示全部楼层
dfdgfdfgd
发表于 2007-9-30 14:04:48 | 显示全部楼层
恩,最近正在准备学习current amp。谢谢楼主
发表于 2007-10-5 10:03:48 | 显示全部楼层
好书啊!谢谢共享!
发表于 2007-10-6 00:09:58 | 显示全部楼层
谢谢楼主,学习中
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-10 19:39 , Processed in 0.024099 second(s), 8 queries , Gzip On, Redis On.
