查看: 11281|回复: 25
[求助] [求助] 帮忙下IEEE论文 Design of novel bootstrap driver used in high power BUCK
发表于 2011-6-24 17:31:48 | 显示全部楼层 |阅读模式
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=5351169&queryText%3Dbootstrap+and+converter%26openedRefinements%3D*%26searchField%3DSearch+All
Design of novel bootstrap driver used in high power BUCK converter
Zekun Zhou; Xing Ming; Bo Zhang; Zhaoji Li;
ASIC, 2009. ASICON '09. IEEE 8th International Conference on
Digital Object Identifier: 10.1109/ASICON.2009.5351169
Publication Year: 2009 , Page(s): 1165 - 1168
IEEE Conferences
Abstract  |  Full Text: PDF (2350 KB)
A novel bootstrap driver suitable for high power buck converter is presented in this paper. With the help of
bootstrap driver, the P type power MOSFET used in conventional buck converter can be replaced by N type power MOSFET
in order to optimize efficiency and area. The proposed bootstrap driver, abandoning conventional level shift
circuit, can work properly in a wide power supply range with sufficient protection. The bootstrap driver has been
validated with UMC 0.6-¿m BCD process based on a monolithic voltage-mode BUCK converter capable of driving up to 3
A loads with supply voltage from 8 to 30 V. Simulation results demonstrate that the power efficiency is over 84% for
load current from 1 A to 3 A, and the buck converter can operate properly under all the application conditions. Read
More»
发表于 2011-6-24 21:33:41 | 显示全部楼层
Design of novel bootstrap driver used in high power BUCK converter.pdf (2.3 MB , 下载次数: 500 )
友情帮你一下,竟然是bozhang组那头的文章......
发表于 2011-6-25 11:09:56 | 显示全部楼层
波哥那边的Power还是挺厉害的啊
发表于 2011-6-25 21:00:53 | 显示全部楼层
xiexie
发表于 2011-9-25 20:11:32 | 显示全部楼层
好东西
发表于 2011-10-23 14:43:35 | 显示全部楼层
好东西啊
发表于 2013-8-13 18:10:30 | 显示全部楼层
不错,不错
发表于 2013-9-12 22:28:42 | 显示全部楼层
回复 1# ant_analog
    挺好的文章,要顶。
发表于 2014-4-17 10:54:22 | 显示全部楼层
不知是什麼東西..但下載來看看..求知域
发表于 2014-4-18 12:51:51 | 显示全部楼层
xuexile
GMT+8, 2025-9-15 07:14 , Processed in 0.021295 second(s), 6 queries , Gzip On, Redis On.
