查看: 18261|回复: 31
[求助] ISE12.3是不是不支持modelsim 10.0呢
发表于 2011-6-16 21:42:07 | 显示全部楼层 |阅读模式
ISE12.3是不是不支持modelsim 10.0呢?
用ISE12.3自带的编译库的程序无法编译库
查看log文件,提示版本不对啊
Library Source Paths => 'd:/Xilinx/12.3/ISE_DS/ISE'
Current Working Directory => 'd:\Xilinx\12.3\ISE_DS\ISE'
Compilation Mode = FAST
Execute Mode = ON
Scheduling library installation & compilation for architectures: all
Scheduling library installation & compilation for libraries: all
Signature:-
compxlib -s mti_se -l all -arch all -lib all -w
ERROR:Compxlib:368 - Compxlib does not support mti_se version 6.3b or prior releases. Parsing through the path setting on your system we have identified that you are using mti_se '2011.02'.
Please contact Mentor Graphics to upgrade to a supported simulator version. If the path setting is incorrect, please ensure that you are pointing to the latest version and re-invoke compxlib.
The list of supported simulator versions are listed in the Simulation Chapter of the Synthesis and Simulation Design Guide on http://www.xilinx.com.
Simulator 'mti_se' is ignored.
发表于 2011-6-17 10:20:42 | 显示全部楼层
试试下面的:
  1》windows cmd命令下进入$env(XILINX)\bin\nt($env(XILINX)表示
     xilinx安装的目录)
  2》cmd运行下列命令
  compxlib -s mti_se -arch all -l all -dir d:\xilinx_libs -w
发表于 2011-6-17 12:07:09 | 显示全部楼层
呵呵,就是不支持,没法编译库文件的。你换6.6吧。
发表于 2011-6-23 10:04:13 | 显示全部楼层
回复 1# gg9132qq
    楼主都用 ModelSim 10 了啊!
    那 ISE 13.1 支持 ModelSim 10 吗?
发表于 2011-7-10 15:24:16 | 显示全部楼层
http://www.xilinx.com/support/answers/38609.htm
看下这里吧,下载里面的附件更新下就可以编译库了,不一定要回到6.6
发表于 2011-8-7 12:42:52 | 显示全部楼层
受用了!
发表于 2011-8-7 23:26:27 | 显示全部楼层
ISE DS最新的是13.2,测试可以支持modelsim 10.0c
发表于 2011-8-8 11:16:21 | 显示全部楼层
我用的6.5,没啥问题
发表于 2012-2-23 21:06:24 | 显示全部楼层
mark 之
发表于 2012-3-1 03:46:32 | 显示全部楼层
mark备用
GMT+8, 2025-9-18 03:16 , Processed in 0.016901 second(s), 3 queries , Gzip On, Redis On.
