查看: 3500|回复: 1
[求助] 在ubuntu11.04下面安装caliber2008,证书破解不完全
发表于 2011-5-26 14:21:26 | 显示全部楼层 |阅读模式
ash下面执行clmli后:Please Note:14:04:16 (lmgrd)
14:04:16 (lmgrd)   This log is intended for debug purposes only.
14:04:16 (lmgrd)   In order to capture accurate license
14:04:16 (lmgrd)   usage data into an organized repository,
14:04:16 (lmgrd)   please enable report logging. Use Macrovision's
14:04:16 (lmgrd)   software license administration  solution,
14:04:16 (lmgrd)   FLEXnet Manager, to  readily gain visibility
14:04:16 (lmgrd)   into license usage data and to create
14:04:16 (lmgrd)   insightful reports on critical information like
14:04:16 (lmgrd)   license availability and usage. FLEXnet Manager
14:04:16 (lmgrd)   can be fully automated to run these reports on
14:04:16 (lmgrd)   schedule and can be used to track license
14:04:16 (lmgrd)   servers and usage across a heterogeneous
14:04:16 (lmgrd)   network of servers including Windows NT, Linux
14:04:16 (lmgrd)   and UNIX. Contact Macrovision at
14:04:16 (lmgrd)   www.macrovision.com for more details on how to
14:04:16 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
14:04:16 (lmgrd)   for your enterprise.
14:04:16 (lmgrd)
14:04:16 (lmgrd)
14:04:16 (lmgrd)
14:04:16 (lmgrd)
14:04:16 (lmgrd) FLEXnet Licensing (v10.8.5.0 build 31891 i86_r6) started on localhost (linux) (5/26/2011)
14:04:16 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
14:04:16 (lmgrd) US Patents 5,390,297 and 5,671,412.14:04:16 (lmgrd) World Wide Web:  http://www.macrovision.com
14:04:16 (lmgrd) License file(s): /home/growler/eda/ic610/calibre/ixl_cal_2008.1_20.15/license.dat
14:04:16 (lmgrd) lmgrd tcp-port 2700114:04:16 (lmgrd) Starting vendor daemons ...
14:04:16 (lmgrd) Started mgcld (internet tcp_port 54988 pid 6155)
14:04:16 (mgcld) FLEXnet Licensing version v10.8.5.0 build 31891 i86_r6
14:04:46 (mgcld) znsimmrt          znsva                 znurf1
14:04:46 (mgcld) znurfl                znvhdl                znview
14:04:46 (mgcld)
14:04:46 (mgcld) Licenses are case sensitive for mgcld
14:04:46 (mgcld)
14:04:46 (mgcld) EXTERNAL FILTERS are OFF
14:04:46 (lmgrd) mgcld using TCP-port 54988
其中:14:04:46 (mgcld) EXTERNAL FILTERS are OFF是不是说明破解不成功阿?我现在是在cadenceIC610下面可以进行DRC,但是没办法保存runset文件阿?求老鸟指导!
发表于 2013-7-8 13:13:25 | 显示全部楼层
ubuntu跟很多EDA工具兼容性不太好,之前我在装calibre2012的时候破解完成后,启动calibre的时候提示不兼容。。。。。。。。。。。。。。
GMT+8, 2025-12-19 20:50 , Processed in 0.015986 second(s), 5 queries , Gzip On, Redis On.
